Datasheet Microchip MCP6544T-E/SL — Даташит
Производитель | Microchip |
Серия | MCP654 |
Модель | MCP6544T-E/SL |
The MCP65x family of operational amplifiers feature low offset.
Datasheet MCP651, MCP651S, MCP652, MCP653, MCP654, MCP655, MCP659
PDF, 1.9 Мб, Язык: анг., Файл опубликован: 7 авг 2014, Страниц: 62
Купить MCP6544T-E/SL на РадиоЛоцман.Цены — от 31 до 142 ₽ 14 предложений от 11 поставщиков Comparator General Purpose CMOS, Push-Pull, Rail-to-Rail, TTL 14-SOIC | |||
MCP6544T-E/SL Microchip | 31 ₽ | ||
MCP6544T-E/SL Microchip | 32 ₽ | ||
MCP6544T-E/SL Microchip | 98 ₽ | ||
MCP6544T-E/SL Microchip | по запросу |
At power-up, these op amps are self-calibrated using mCal. Some package options also provide a calibration/chip select pin that supports a low power mode of operation, with offset calibration at the time normal operation is re-started. These amplifiers are optimized for high speed, low noise and distortion, single-supply operation with rail-to-rail output and an input that includes the negative rail. AEC-Q100 Grade 1 qualification is available for this device
Корпус | SOIC |
Количество каналов | 4 |
Aol | 114 дБ |
Automotive Recommended | Yes |
CMRR Min | 66 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 50000 kHz |
Ib | 6 pA |
Input Voltage Noise Density | 7.5 nV/rt(Hz) |
Iq Max | 9000 µA |
Iq Typical | 6000 µA |
Isc | 95 мА |
Lead Count | 14 |
Operating Voltage Range | 2.5 - 5.5 В |
PM | 65 deg |
PSRR Min | 61 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | Out |
Скорость нарастания | 30 V/µS |
Unity Gain Stable | Yes |
Vos Max | 200 µV |
ΔVos/ΔTa | 2.5 µV/°C |
MCP651 MCP651S MCP652 MCP653 MCP655 MCP659
Серия: MCP654 (100 из 110)
- MCP654-E/SL MCP654-E/ST MCP6541-E/MS MCP6541-E/P MCP6541-E/SN MCP6541-I/MS MCP6541-I/P MCP6541-I/SN MCP6541RT-E/OT MCP6541RT-I/OT MCP6541T-E/MS MCP6541T-E/OT MCP6541T-E/OTVAO MCP6541T-E/SN MCP6541T-I/LT MCP6541T-I/MS MCP6541T-I/OT MCP6541T-I/SN MCP6541UT-E/OT MCP6541UT-I/LT MCP6542-E/MS MCP6542-E/P MCP6542-E/SN MCP6542-I/MS MCP6542-I/P MCP6542-I/SN MCP6542T-E/MS MCP6542T-E/SN MCP6542T-E/SNVAO MCP6542T-I/MS MCP6542T-I/SN MCP6543-E/MS MCP6543-E/P MCP6543-E/SN MCP6543-I/MS MCP6543-I/P MCP6543-I/SN MCP6543T-E/MS MCP6543T-E/SN MCP6543T-I/MS MCP6543T-I/SN MCP6544-E/P MCP6544-E/SL MCP6544-E/ST MCP6544-E/STVAO MCP6544-I/P MCP6544-I/SL MCP6544-I/ST MCP6544T-E/SL MCP6544T-E/ST MCP6544T-E/STVAO MCP6544T-I/SL MCP6544T-I/ST MCP6546-E/MS MCP6546-E/P MCP6546-E/SN MCP6546-I/MS MCP6546-I/P MCP6546-I/SN MCP6546RT-E/OT MCP6546RT-I/OT MCP6546T-E/MS MCP6546T-E/OT MCP6546T-E/OTVAO MCP6546T-E/SN MCP6546T-I/LT MCP6546T-I/MS MCP6546T-I/OT MCP6546T-I/SN MCP6546UT-E/OT MCP6546UT-E/OTVAO MCP6546UT-I/LT MCP6547-E/MS MCP6547-E/P MCP6547-E/SN MCP6547-I/MS MCP6547-I/P MCP6547-I/SN MCP6547T-E/MS MCP6547T-E/MSVAO MCP6547T-E/SN MCP6547T-I/MS MCP6547T-I/SN MCP6547T-I/SNVAO MCP6548-E/MS MCP6548-E/P MCP6548-E/SN MCP6548-I/MS MCP6548-I/P MCP6548-I/SN MCP6548T-E/MS MCP6548T-E/SN MCP6548T-I/MS MCP6548T-I/SN MCP6549-E/P MCP6549-E/SL MCP6549-E/ST MCP6549-I/P MCP6549-I/SL MCP6549-I/ST
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6544TE/SL, MCP6544T E/SL
