Datasheet Microchip AT32UC3B0512-A2UT — Даташит
Производитель | Microchip |
Серия | AT32UC3B0512 |
Модель | AT32UC3B0512-A2UT |
The high-performance, low-power 32-bit AVR RISC-based microcontroller combines 512KB flash memory, 32KB SRAM, full-speed (12 Mbps) USB Mini-host + device, and I2S
Купить AT32UC3B0512-A2UT на РадиоЛоцман.Цены — от 454 до 2 902 ₽ 26 предложений от 16 поставщиков AVR AVR®32 UC3 B Microcontroller IC 32-Bit Single-Core 60MHz 512KB (512K x 8) FLASH 64-TQFP (10x10) | |||
AT32UC3B0512-A2UT Atmel | 454 ₽ | ||
AT32UC3B0512-A2UT Microchip | 517 ₽ | ||
AT32UC3B0512-A2UT Microchip | 746 ₽ | ||
AT32UC3B0512-A2UT Microchip | 1 797 ₽ |
Корпус | TQFP |
Количество выводов | 64 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit AVR |
CRC/Scan | No |
Cap. Touch Channels | 32 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 115Khz |
Math Accelerator | No |
Max # PWM outputs | 13 including complementary outputs |
Max 16 Bit Digital Timers | 3 |
Max A/D Resolution | 10 bits |
Max D/A Resolution | 16 bits |
Max. CPU Speed MHz | 60 |
Number of USB Modules | 1 |
Pin count | 64 |
Размер памяти программ | 512 Kbytes |
RAM | 98304 bytes |
SPIв„ў | 4 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
UART | 3 |
Zero Cross detect | No |
AT32UC3A0128 AT32UC3A0256 AT32UC3A0512 AT32UC3A1128 AT32UC3A1256 AT32UC3A1512 AT32UC3A3128 AT32UC3A3128S AT32UC3A3256 AT32UC3A3256S AT32UC3A364 AT32UC3A364S AT32UC3A4128 AT32UC3A4128S AT32UC3A4256 AT32UC3A4256S AT32UC3A464 AT32UC3A464S AT32UC3B0128 AT32UC3B0256 AT32UC3B064 AT32UC3B1128 AT32UC3B1256 AT32UC3B1512 AT32UC3B164 AT32UC3C0128C AT32UC3C0256C AT32UC3C0512C AT32UC3C0512C-AUTOMOTIVE AT32UC3C064C AT32UC3C1128C AT32UC3C1256C AT32UC3C1512C AT32UC3C1512C-AUTOMOTIVE AT32UC3C164C AT32UC3C2128C AT32UC3C2256C AT32UC3C2512C AT32UC3C2512C-AUTOMOTIVE AT32UC3C264C AT32UC3L0128 AT32UC3L0256 ATUC128D3 ATUC128L3U ATUC128L4U ATUC256L3U ATUC256L4U ATUC64D3 ATUC64D4 ATUC64L3U ATUC64L4U
- AT32UC3B0512-A2UR AT32UC3B0512-A2UT AT32UC3B0512-Z2UR AT32UC3B0512-Z2UT
AT32UC3B0512A2UT, AT32UC3B0512 A2UT
