Datasheet Microchip ATSAMC21N18A — Даташит
Производитель | Microchip |
Серия | ATSAMC21N18A |
The Microchip SAM C series of 5V Cortex M0+ devices is designed for industrial and commercial applications in noisy environments
Купить ATSAMC21N18A на РадиоЛоцман.Цены — от 280 до 16 775 ₽ 24 предложений от 12 поставщиков ARM® Cortex®-M0+ SAM C21, Functional Safety (FuSa) Microcontroller IC 32-Bit Single-Core 48MHz 256KB (256K x 8) FLASH 100-TQFP (14x14) | |||
ATSAMC21N18A-ANT Microchip | 280 ₽ | ||
ATSAMC21N18A-AN Microchip | от 395 ₽ | ||
ATSAMC21N18A-ANT Microchip | 838 ₽ | ||
ATSAMC21N18A-ANT Microchip | от 917 ₽ |
ATSAMC21N18A-ANT | |
N | 1 |
Корпус | TQFP |
Количество выводов | 100 |
Parameters / Models | ATSAMC21N18A-ANT |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 256 |
High Voltage Capable | No |
I2C | 6 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 26 |
Max 8 Bit Digital Timers | 5 |
Max A/D Resolution, bits | 12 |
Max D/A Resolution, bits | 10 |
Max. CPU Speed MHz | 48 |
Number of USB Modules | 1 |
Рабочий диапазон температур, °C | от -40 до +105 |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 1.62 |
Peripheral Pin Select, PPS | Yes |
Pin count | 64 |
Размер памяти программ, Kbytes | 256 |
RAM, bytes | 32768 |
SPIв„ў | 6 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 20 |
UART | 6 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20E18A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20G18A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N17A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G17A ATSAMC21G18A ATSAMC21J17A ATSAMC21J18A ATSAMC21N17A
Серия: ATSAMC21N18A (1)
