Datasheet Microchip ATSAMD09C13 — Даташит
Производитель | Microchip |
Серия | ATSAMD09C13 |
The low-power, high-performance Microchip's ATSAMD09C13 ARM® Cortex®-M0+ based flash microcontroller is ideal for a wide range of home automation, consumer, metering and industrial applications
Купить ATSAMD09C13 на РадиоЛоцман.Цены — от 31 до 2 727 ₽ 24 предложений от 14 поставщиков Микроконтроллер ARM, SMART SAMD09, SAM32 Family SAM D1X Series Microcontrollers, ARM Cortex-M0+ | |||
ATSAMD09C13A-SSUT Microchip | 31 ₽ | ||
ATSAMD09C13A-SSUT Microchip | от 226 ₽ | ||
ATSAMD09C13A-SSUT Microchip | по запросу |
ATSAMD09C13A-SSUT | |
N | 1 |
Корпус | SOIC |
Количество выводов | 14 |
Parameters / Models | ATSAMD09C13A-SSUT |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 2 |
Max 16 Bit Digital Timers | 2 |
Max 8 Bit Digital Timers | 2 |
Max A/D Resolution, bits | 12 |
Max. CPU Speed MHz | 48 |
Рабочий диапазон температур, °C | от -40 до +85 |
Operation Voltage Min.(V) | 2.4 |
Peripheral Pin Select, PPS | Yes |
Pin count | 14 |
Размер памяти программ, Kbytes | 8 |
RAM, bytes | 4096 |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 5 |
UART | 2 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
Серия: ATSAMD09C13 (1)
