Datasheet Microchip ATSAMD20J17A-CN — Даташит
Производитель | Microchip |
Серия | ATSAMD20J17 |
Модель | ATSAMD20J17A-CN |
A low-power, high-performance Microchip's ARM® Cortex®-M0+ based flash microcontroller, the ATSAMD20J17 is ideal for a wide range of home automation, consumer, metering, and industrial applications
Купить ATSAMD20J17A-CN на РадиоЛоцман.Цены — от 153 до 533 ₽ 11 предложений от 11 поставщиков ARM® Cortex®-M0+ SAM D20J Microcontroller IC 32-Bit Single-Core 48MHz 128KB (128K x 8) FLASH 64-UFBGA (5x5) | |||
ATSAMD20J17A-CN Microchip | 153 ₽ | ||
ATSAMD20J17A-CN Atmel | 156 ₽ | ||
ATSAMD20J17A-CN Microchip | 213 ₽ | ||
ATSAMD20J17A-CN Microchip | по запросу |
Корпус | UFBGA |
Количество выводов | 64 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 256 |
High Voltage Capable | No |
I2C | 6 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Math Accelerator | No |
Max # PWM outputs | 16 including complementary outputs |
Max 8 Bit Digital Timers | 5 |
Max D/A Resolution | 10 bits |
Max. CPU Speed MHz | 48 |
Рабочий диапазон температур | от -40 до +105 °C |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 64 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 6 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 20 |
UART | 6 |
Zero Cross detect | No |
ATSAMD20E14 ATSAMD20E15 ATSAMD20E16 ATSAMD20E17 ATSAMD20E18 ATSAMD20G14 ATSAMD20G15 ATSAMD20G16 ATSAMD20G17 ATSAMD20G18 ATSAMD20J14 ATSAMD20J15 ATSAMD20J16 ATSAMD20J18
Серия: ATSAMD20J17 (12)
ATSAMD20J17ACN, ATSAMD20J17A CN
