Datasheet Microchip ATTINY102-SSFR — Даташит
Производитель | Microchip |
Серия | ATtiny102 |
Модель | ATTINY102-SSFR |
The high-performance Microchip's tinyAVR 8-bit RISC-based ATtiny102 microcontroller (MCU) combines 1KB in-system programmable Flash memory, 32 Bytes SRAM, six general-purpose I/O lines, 16 general-purpose working registers, one 16-bit timer/counter with two PWM channels, internal and external interrupts, a 5-channel 10-bit A/D converter, on-chip analog comparator, one full duplex USART, programmable watchdog timer with internal oscillator, internal calibrated oscillator, 10-bytes unique ID (serial number), three calibrated internal voltage references (1
ATtiny102/104 - Complete Datasheet
PDF, 3.8 Мб, Файл опубликован: 10 дек 2016
ATtiny102/104 - Summary Datasheet
PDF, 806 Кб, Файл опубликован: 10 дек 2016
Купить ATTINY102-SSFR на РадиоЛоцман.Цены — от 37 до 164 ₽ 23 предложений от 11 поставщиков AVR, 1KB SELF-PROGRAMMABLE FLASH, 32B SRAM, ADC - 12MHz, SOIC, High Grade (+125C), Green | |||
ATTINY102-SSFR Microchip | 37 ₽ | ||
ATTINY102-SSFR Atmel | 46 ₽ | ||
ATTINY102-SSFR | от 141 ₽ | ||
ATTINY102-SSFR Microchip | по запросу |
Корпус | SOIC |
ADC Input | 5 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
High Voltage Capable | No |
Internal Oscillator | Yes |
Lead Count | 8 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max CPU Speed | 12 МГц |
Max PWM outputs | 2 including complementary |
Package Width | .150In(3.90mm) |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 8 |
Размер памяти программ | 1 KB |
SRAM | 32 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: ATtiny102 (12)
- Microcontrollers > 8-bit Microcontrollers
ATTINY102SSFR, ATTINY102 SSFR
