Datasheet Microchip ATtiny102 — Даташит
Производитель | Microchip |
Серия | ATtiny102 |
The high-performance Microchip's tinyAVR 8-bit RISC-based ATtiny102 microcontroller (MCU) combines 1KB in-system programmable Flash memory, 32 Bytes SRAM, six general-purpose I/O lines, 16 general-purpose working registers, one 16-bit timer/counter with two PWM channels, internal and external interrupts, a 5-channel 10-bit A/D converter, on-chip analog comparator, one full duplex USART, programmable watchdog timer with internal oscillator, internal calibrated oscillator, 10-bytes unique ID (serial number), three calibrated internal voltage references (1
ATtiny102/104 - Complete Datasheet
PDF, 3.8 Мб, Файл опубликован: 10 дек 2016
ATtiny102/104 - Summary Datasheet
PDF, 806 Кб, Файл опубликован: 10 дек 2016
Купить ATtiny102 на РадиоЛоцман.Цены — от 37 до 154 ₽ 27 предложений от 13 поставщиков 8 Bit MCU, AVR ATtiny Family ATtiny10 Series Microcontrollers, 12 МГц, 1 КБ, 32 Байт | |||
ATTINY102-SSFR Microchip | 37 ₽ | ||
ATTINY102-MNR Atmel | 40 ₽ | ||
ATTINY102-SSNR Atmel | 51 ₽ | ||
ATTINY102-SSNR Microchip | от 58 ₽ |
ATTINY102-M7R | ATTINY102-M8R | ATTINY102-SSF | ATTINY102-SSFR | ATTINY102-SSN | ATTINY102-SSNR | ATTINY102F-M7R | ATTINY102F-M8R | ATTINY102F-SSF | ATTINY102F-SSFR | ATTINY102F-SSN | ATTINY102F-SSNR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | UDFN | UDFN | SOIC | SOIC | SOIC | SOIC | UDFN | UDFN | SOIC | SOIC | SOIC | SOIC |
Parameters / Models | ATTINY102-M7R | ATTINY102-M8R | ATTINY102-SSF | ATTINY102-SSFR | ATTINY102-SSN | ATTINY102-SSNR | ATTINY102F-M7R | ATTINY102F-M8R | ATTINY102F-SSF | ATTINY102F-SSFR | ATTINY102F-SSN | ATTINY102F-SSNR |
ADC Input | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
ADC with Computation | No | No | No | No | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No | No | No | No | No |
High Voltage Capable | No | No | No | No | No | No | No | No | No | No | No | No |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
Math Accelerator | No | No | No | No | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
Max PWM outputs, including complementary | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 2x3x0.6mm | 2x3x0.6mm | .150In(3.90mm) | .150In(3.90mm) | .150In(3.90mm) | .150In(3.90mm) | 2x3x0.6mm | 2x3x0.6mm | .150In(3.90mm) | .150In(3.90mm) | .150In(3.90mm) | .150In(3.90mm) |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No | No | No | No |
Pin count | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
Размер памяти программ, KB | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
SRAM, Bytes | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Temp Range Max | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Zero Cross detect | No | No | No | No | No | No | No | No | No | No | No | No |
Серия: ATtiny102 (12)
- Microcontrollers > 8-bit Microcontrollers
