Datasheet Intersil ISL9238 — Даташит
Производитель | Intersil |
Серия | ISL9238 |
Зарядное устройство Buck-Boost узкого напряжения постоянного тока с интерфейсом SMBus и USB OTG
Купить ISL9238 на РадиоЛоцман.Цены — от 76 до 956 ₽ 20 предложений от 12 поставщиков Switching Battery Charger Li-Ion/Li-Pol 2.4V to 18.304V 32-Pin TQFN EP T/R | |||
ISL88750HRZ ISL6236IRZ ISL6237IRZ ISL95520AHRZ ISL9237HRZ ISL81601FRZ ISL62381HRTZ ISL9238CIRTZ ISL59446IRZ IC, | 76 ₽ | ||
ISL9238AHRTZ Intel | от 145 ₽ | ||
ISL9238AHRTZ-TK Intersil | 310 ₽ | ||
ISL9238BHRTZ-T Renesas | 422 ₽ |
ISL9238HRTZ | ISL9238HRTZ-T | ISL9238HRTZ-T7A | ISL9238HRTZ-TK | ISL9238IRTZ | ISL9238IRTZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 32 Ld TQFN | 32 Ld TQFN T+R | 32 Ld TQFN T+R | 32 Ld TQFN T+R | 32 Ld TQFN | 32 Ld TQFN T+R |
Parameters / Models | ISL9238HRTZ | ISL9238HRTZ-T | ISL9238HRTZ-T7A | ISL9238HRTZ-TK | ISL9238IRTZ | ISL9238IRTZ-T |
Audible Noise | No | No | No | No | No | No |
Automatic Power Source Selection | Yes | Yes | Yes | Yes | Yes | Yes |
Battery Charge Voltage (V) | 2.4 to 18.304 | 2.4 to 18.304 | 2.4 to 18.304 | 2.4 to 18.304 | 2.4 to 18.304 | 2.4 to 18.304 |
Battery Charge Voltage Adjust (%) | 8mV steps | 8mV steps | 8mV steps | 8mV steps | 8mV steps | 8mV steps |
Battery Chemistry | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer |
Charge Current Limit Accuracy (%) | В±3 | В±3 | В±3 | В±3 | В±3 | В±3 |
Charging Voltage Accuracy Max (%) | В±0.5 | В±0.5 | В±0.5 | В±0.5 | В±0.5 | В±0.5 |
DC Adapter Detection | Yes | Yes | Yes | Yes | Yes | Yes |
Description | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG | Buck-Boost Narrow VDC Battery Charger with SMBus Interface and USB OTG |
Max Duty Cycle (%) | 100 | 100 | 100 | 100 | 100 | 100 |
Рабочий диапазон температур | от -40 до 100 | от -40 до 100 | от -40 до 100 | от -40 до 100 | от -40 до 100 | от -40 до 100 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
Switching Frequency (typ) (kHz) | 733 or 1000 | 733 or 1000 | 733 or 1000 | 733 or 1000 | 733 or 1000 | 733 or 1000 |
Thermal Shutdown (В°C) | 150 °C | 150 °C | 150 °C | 150 °C | 150 °C | 150 °C |
Topology | R3 modulator | R3 modulator | R3 modulator | R3 modulator | R3 modulator | R3 modulator |
Trickle Charge Current Limit Accuracy (%) | 64mA, 128mA, 256mA, or 512mA | 64mA, 128mA, 256mA, or 512mA | 64mA, 128mA, 256mA, or 512mA | 64mA, 128mA, 256mA, or 512mA | 64mA, 128mA, 256mA, or 512mA | 64mA, 128mA, 256mA, or 512mA |
VIN (max) (V) | 23.4 | 23.4 | 23.4 | 23.4 | 23.4 | 23.4 |
VIN (min) (V) | 3.2 | 3.2 | 3.2 | 3.2 | 3.2 | 3.2 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL9238 (6)
- Power Management > Battery Management Systems > Multiple Cell Battery Chargers
