Datasheet Microchip dsPIC33EP16GS505 — Даташит
Производитель | Microchip |
Серия | dsPIC33EP16GS505 |
dsPIC33EPXXGS50X is a SMPS & Digital Power Conversion Digital Signal Controller
Купить dsPIC33EP16GS505 на РадиоЛоцман.Цены — от 278 до 691 ₽ 6 предложений от 6 поставщиков dsPIC dsPICTM33EP, Functional Safety (FuSa) Microcontroller IC 16-Bit 70 MIPs 16KB (16K x 8) FLASH 48-TQFP (7x7) | |||
DSPIC33EP16GS505-I/PT Microchip | 278 ₽ | ||
DSPIC33EP16GS505-I/PT Microchip | 682 ₽ | ||
DSPIC33EP16GS505-I/PT Microchip | по запросу | ||
DSPIC33EP16GS505T-E/PT Microchip | по запросу |
DSPIC33EP16GS505-E/PT | DSPIC33EP16GS505-I/PT | DSPIC33EP16GS505T-E/PT | DSPIC33EP16GS505T-I/PT | |
Статус продукта | Samples Available | Samples Available | Samples Available | Samples Available |
N | 1 | 2 | 3 | 4 |
Корпус | TQFP | TQFP | TQFP | TQFP |
Количество выводов | 48 | 48 | 48 | 48 |
Parameters / Models | DSPIC33EP16GS505-E/PT | DSPIC33EP16GS505-I/PT | DSPIC33EP16GS505T-E/PT | DSPIC33EP16GS505T-I/PT |
# of Comparators | 4 | 4 | 4 | 4 |
ADCC with Computation | No | No | No | No |
Angular Timer | No | No | No | No |
Архитектура | 16 | 16 | 16 | 16 |
CPU | 16-bit dsPIC DSC | 16-bit dsPIC DSC | 16-bit dsPIC DSC | 16-bit dsPIC DSC |
CRC/Scan | No | No | No | No |
EEPROM / HEF | 0 / HEF | 0 / HEF | 0 / HEF | 0 / HEF |
High Voltage Capable | No | No | No | No |
I2C | 2 | 2 | 2 | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes |
Math Accelerator | No | No | No | No |
Max # PWM outputs, including complementary outputs | 10 | 10 | 10 | 10 |
Max 16 Bit Digital Timers | 5 | 5 | 5 | 5 |
Max A/D Resolution, bits | 12 | 12 | 12 | 12 |
Max D/A Resolution, bits | 12 | 12 | 12 | 12 |
Max PWM Resolution, bits | 16 | 16 | 16 | 16 |
Max. CPU Speed MHz | 70 | 70 | 70 | 70 |
Number of D/A Converters | 4 | 4 | 4 | 4 |
Рабочий диапазон температур, °C | от -40 до +125 | от -40 до +85 | от -40 до +125 | от -40 до +85 |
Operation Voltage Max.(V) | 3.6 | 3.6 | 3.6 | 3.6 |
Operation Voltage Min.(V) | 3 | 3 | 3 | 3 |
Peripheral Pin Select, PPS | Yes | Yes | Yes | Yes |
Pin count | 48 | 48 | 48 | 48 |
Размер памяти программ, Kbytes | 16 | 16 | 16 | 16 |
RAM, bytes | 4096 | 4096 | 4096 | 4096 |
SPIв„ў | 2 | 2 | 2 | 2 |
Temp. Range Max. | 125 | 125 | 125 | 125 |
Temp. Range Min. | -40 | -40 | -40 | -40 |
Total # of A/D channels | 19 | 19 | 19 | 19 |
UART | 2 | 2 | 2 | 2 |
Windowed Watchdog Timer, WWDT | No | No | No | No |
Zero Cross detect | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим |
dsPIC33EP16GS502 dsPIC33EP16GS504 dsPIC33EP16GS506 dsPIC33EP32GS502 dsPIC33EP32GS504 dsPIC33EP32GS505 dsPIC33EP32GS506 dsPIC33EP64GS502 dsPIC33EP64GS504 dsPIC33EP64GS505 dsPIC33EP64GS506
Серия: dsPIC33EP16GS505 (4)
