Datasheet Microchip DSPIC33EP64GS502-I/SO — Даташит
Производитель | Microchip |
Серия | dsPIC33EP64GS502 |
Модель | DSPIC33EP64GS502-I/SO |
dsPIC33EPXXGS50X is a SMPS & Digital Power Conversion Digital Signal Controller
Купить DSPIC33EP64GS502-I/SO на РадиоЛоцман.Цены — от 32 до 1 210 ₽ 19 предложений от 13 поставщиков dsPIC dsPICTM33EP, Functional Safety (FuSa) Microcontroller IC 16-Bit 70 MIPs 64KB (64K x 8) FLASH 28-SOIC | |||
DSPIC33EP64GS502-I/SO Microchip | 32 ₽ | ||
DSPIC33EP64GS502-I/SO Microchip | 33 ₽ | ||
DSPIC33EP64GS502-I/SO Microchip | 291 ₽ | ||
DSPIC33EP64GS502-I/SO Microchip | по запросу |
Корпус | SOIC |
Количество выводов | 28 |
# of Comparators | 4 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 10 including complementary outputs |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 70 |
Number of D/A Converters | 4 |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 64 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 2 |
Zero Cross detect | No |
dsPIC33EP16GS502 dsPIC33EP16GS504 dsPIC33EP16GS505 dsPIC33EP16GS506 dsPIC33EP32GS502 dsPIC33EP32GS504 dsPIC33EP32GS505 dsPIC33EP32GS506 dsPIC33EP64GS504 dsPIC33EP64GS505 dsPIC33EP64GS506
Серия: dsPIC33EP64GS502 (12)
DSPIC33EP64GS502I/SO, DSPIC33EP64GS502 I/SO
