Datasheet Microchip DSPIC33FJ06GS101A-I/P — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ06GS101A |
Модель | DSPIC33FJ06GS101A-I/P |
dsPIC33FJXXGSXXX SMPS & Digital Power Conversion 16-bit Digital Signal Controller
dsPIC33FJ06GS001/101A/102A/202A and dsPIC33FJ09GS302 Data Sheet
PDF, 3.4 Мб, Версия: 08-21-2012
![]() 17 предложений от 13 поставщиков dsPIC dsPICTM33F Microcontroller IC 16-Bit 40 MIPs 6KB (2K x 24) FLASH 18-PDIP | |||
DSPIC33FJ06GS101A-I/P Microchip | 150 ₽ | ||
DSPIC33FJ06GS101A-I/P Microchip | 225 ₽ | ||
DSPIC33FJ06GS101A-I/P Microchip | 525 ₽ | ||
DSPIC33FJ06GS101A-I/P Microchip | 593 ₽ |
Корпус | PDIP |
Количество выводов | 18 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
Cap. Touch Channels | 6 |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 5 including complementary outputs |
Max 16 Bit Digital Timers | 2 |
Max A/D Resolution | 10 bits |
Max. CPU Speed MHz | 40 |
Operation Voltage Min.(V) | 3 |
Pin count | 18 |
Размер памяти программ | 6 Kbytes |
RAM | 256 bytes |
SPIв„ў | 1 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 6 |
UART | 1 |
Zero Cross detect | No |
dsPIC33FJ06GS001 dsPIC33FJ06GS102A dsPIC33FJ06GS202A dsPIC33FJ09GS302
Серия: dsPIC33FJ06GS101A (4)
- DSPIC33FJ06GS101A-I/P DSPIC33FJ06GS101A-I/SO DSPIC33FJ06GS101A-I/SS DSPIC33FJ06GS101AT-I/SO
DSPIC33FJ06GS101AI/P, DSPIC33FJ06GS101A I/P
