Datasheet Microchip PIC16F1503T-E/SLVAO — Даташит
Производитель | Microchip |
Серия | PIC16F1503 |
Модель | PIC16F1503T-E/SLVAO |
Debug Support • External debug header (AC244051/AC244052) is needed for debug support • Debug and Programming support is available via PICkit™ 3, and MPLAB® ICD 3
PIC16(L)F1503 14-Pin Flash, 8-Bit MCU Data Sheet
PDF, 3.3 Мб, Файл опубликован: 10 дек 2015
PIC16F1503T-E/SLVAO Micra | по запросу |
Корпус | SOIC |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 2 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 16 MHz |
Lead Count | 14 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 5 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | .150In(3.90mm) |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 14 |
Размер памяти программ | 3.5 KB |
SPI | 1 |
SRAM | 128 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: PIC16F1503 (49)
- PIC16F1503-E/MG PIC16F1503-E/MV PIC16F1503-E/P PIC16F1503-E/SL PIC16F1503-E/SLVAO PIC16F1503-E/ST PIC16F1503-E/STVAO PIC16F1503-H/MGVAO PIC16F1503-H/STVAO PIC16F1503-I/MG PIC16F1503-I/MGVAO PIC16F1503-I/MV PIC16F1503-I/P PIC16F1503-I/SL PIC16F1503-I/ST PIC16F1503-I/STVAO PIC16F1503T-E/MG PIC16F1503T-E/MGVAO PIC16F1503T-E/MV PIC16F1503T-E/MVVAO PIC16F1503T-E/SL PIC16F1503T-E/SLVAO PIC16F1503T-E/ST PIC16F1503T-E/STVAO PIC16F1503T-H/MGVAO PIC16F1503T-H/STVAO PIC16F1503T-I/MG PIC16F1503T-I/MGVAO PIC16F1503T-I/MV PIC16F1503T-I/SL PIC16F1503T-I/SLVAO PIC16F1503T-I/ST PIC16F1503T-I/STVAO PIC16LF1503-E/MG PIC16LF1503-E/MV PIC16LF1503-E/P PIC16LF1503-E/SL PIC16LF1503-E/ST PIC16LF1503-I/MG PIC16LF1503-I/MV PIC16LF1503-I/P PIC16LF1503-I/SL PIC16LF1503-I/ST PIC16LF1503T-E/MG PIC16LF1503T-E/MV PIC16LF1503T-I/MG PIC16LF1503T-I/MV PIC16LF1503T-I/SL PIC16LF1503T-I/ST
- Microcontrollers > 8-bit Microcontrollers
PIC16F1503TE/SLVAO, PIC16F1503T E/SLVAO
