Datasheet Microchip PIC16LF1507-I/GZ — Даташит
Производитель | Microchip |
Серия | PIC16F1507 |
Модель | PIC16LF1507-I/GZ |
Debug Support • External debug header (AC244051/AC244052) is needed for debug support • Debug and Programming support is available via PICkit™ 3, and MPLAB® ICD 3
PIC16(L)F1507 20-Pin Flash, 8-Bit MCUs Data Sheet
PDF, 2.7 Мб, Файл опубликован: 10 дек 2015
Купить PIC16LF1507-I/GZ на РадиоЛоцман.Цены — от 55 до 7 243 ₽ 7 предложений от 7 поставщиков PIC PIC® 16F Microcontroller IC 8-Bit 20MHz 3.5KB (2K x 14) FLASH 20-UQFN (4x4) | |||
PIC16LF1507-I/GZ Microchip | 55 ₽ | ||
PIC16LF1507-I/GZ Microchip | 82 ₽ | ||
PIC16LF1507-I/GZ Microchip | 83 ₽ | ||
PIC16LF1507-I/GZ Microchip | по запросу |
Корпус | UQFN |
Количество выводов | 20 |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 2 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
Internal Oscillator | 16 MHz, 32 kHz |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 5 including complementary |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 20 |
Размер памяти программ | 3.5 KB |
SRAM | 128 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: PIC16F1507 (37)
- PIC16F1507-E/GZ PIC16F1507-E/ML PIC16F1507-E/P PIC16F1507-E/SO PIC16F1507-E/SS PIC16F1507-H/MLVAO PIC16F1507-H/SSVAO PIC16F1507-I/GZ PIC16F1507-I/ML PIC16F1507-I/P PIC16F1507-I/SO PIC16F1507-I/SS PIC16F1507-I/SSVAO PIC16F1507T-E/GZ PIC16F1507T-E/ML PIC16F1507T-E/SS PIC16F1507T-H/MLVAO PIC16F1507T-H/SSVAO PIC16F1507T-I/GZ PIC16F1507T-I/ML PIC16F1507T-I/SO PIC16F1507T-I/SS PIC16F1507T-I/SSVAO PIC16LF1507-E/GZ PIC16LF1507-E/ML PIC16LF1507-E/P PIC16LF1507-E/SO PIC16LF1507-E/SS PIC16LF1507-I/GZ PIC16LF1507-I/ML PIC16LF1507-I/P PIC16LF1507-I/SO PIC16LF1507-I/SS PIC16LF1507T-I/GZ PIC16LF1507T-I/ML PIC16LF1507T-I/SO PIC16LF1507T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1507I/GZ, PIC16LF1507 I/GZ
