Datasheet Microchip PIC16F1508T-E/SS — Даташит
Производитель | Microchip |
Серия | PIC16F1508 |
Модель | PIC16F1508T-E/SS |
Debug Support 'ў External debug header (AC244051/AC244052) is needed for debug support 'ў Debug and Programming support is available via PICkit 3, and MPLAB ICD 3
PIC16(L)F1508/9 20-Pin Flash, 8-Bit MCU with XLP Technology
PDF, 4.0 Мб, Файл опубликован: 28 окт 2015
Купить PIC16F1508T-E/SS на РадиоЛоцман.Цены — от 87 до 88 ₽ | |||
PIC16F1508T-E/SS Microchip | 87 ₽ | ||
PIC16F1508T-E/SS Microchip | 88 ₽ | ||
PIC16F1508T-E/SS Micra | по запросу |
Корпус | SSOP |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 4 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 16 MHz, 32 kHz |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 5 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | .209in |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 20 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 256 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F1508 (44)
- PIC16F1508-E/GZ PIC16F1508-E/ML PIC16F1508-E/MLVAO PIC16F1508-E/P PIC16F1508-E/SO PIC16F1508-E/SS PIC16F1508-E/SSVAO PIC16F1508-H/MLVAO PIC16F1508-I/GZ PIC16F1508-I/ML PIC16F1508-I/MLVAO PIC16F1508-I/P PIC16F1508-I/SO PIC16F1508-I/SS PIC16F1508-I/SSVAO PIC16F1508T-E/GZ PIC16F1508T-E/ML PIC16F1508T-E/MLVAO PIC16F1508T-E/SO PIC16F1508T-E/SOV07 PIC16F1508T-E/SS PIC16F1508T-E/SSVAO PIC16F1508T-H/MLVAO PIC16F1508T-H/SSVAO PIC16F1508T-I/GZ PIC16F1508T-I/ML PIC16F1508T-I/MLVAO PIC16F1508T-I/SO PIC16F1508T-I/SS PIC16F1508T-I/SSVAO PIC16LF1508-E/GZ PIC16LF1508-E/ML PIC16LF1508-E/P PIC16LF1508-E/SO PIC16LF1508-E/SS PIC16LF1508-I/GZ PIC16LF1508-I/ML PIC16LF1508-I/P PIC16LF1508-I/SO PIC16LF1508-I/SS PIC16LF1508T-I/GZ PIC16LF1508T-I/ML PIC16LF1508T-I/SO PIC16LF1508T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16F1508TE/SS, PIC16F1508T E/SS
