Datasheet Microchip PIC16F1509-H/SSVAO — Даташит
Производитель | Microchip |
Серия | PIC16F1509 |
Модель | PIC16F1509-H/SSVAO |
Debug Support • External debug header (AC244051/AC244052) is needed for debug support • Debug and Programming support is available via PICkit™ 3, and MPLAB® ICD 3
PIC16(L)F1508/9 20-Pin Flash, 8-Bit MCU with XLP Technology
PDF, 4.0 Мб, Файл опубликован: 28 окт 2015
Купить PIC16F1509 на РадиоЛоцман.Цены — от 31 до 5 087 ₽ 36 предложений от 24 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 20MHz 14KB (8K x 14) FLASH 20-PDIP | |||
PIC16F1509T-I/SO Microchip | 31 ₽ | ||
PIC16F1509T-I/SO Microchip | 33 ₽ | ||
PIC16F1509-I/GZ Microchip | 66 ₽ | ||
PIC16F1509-I/SS Microchip | 239 ₽ |
Корпус | SSOP |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 4 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 16 MHz, 32 kHz |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 5 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | .209in |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 20 |
Размер памяти программ | 14 KB |
SPI | 1 |
SRAM | 512 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F1509 (43)
- PIC16F1509-E/GZ PIC16F1509-E/GZVAO PIC16F1509-E/ML PIC16F1509-E/MLVAO PIC16F1509-E/P PIC16F1509-E/SO PIC16F1509-E/SS PIC16F1509-E/SSVAO PIC16F1509-H/SSVAO PIC16F1509-I/GZ PIC16F1509-I/ML PIC16F1509-I/P PIC16F1509-I/SO PIC16F1509-I/SS PIC16F1509-ICE/SP PIC16F1509T-E/GZ PIC16F1509T-E/GZV10 PIC16F1509T-E/GZVAO PIC16F1509T-E/ML PIC16F1509T-E/MLVAO PIC16F1509T-E/SS PIC16F1509T-E/SSVAO PIC16F1509T-H/SSVAO PIC16F1509T-I/GZ PIC16F1509T-I/ML PIC16F1509T-I/MLVAO PIC16F1509T-I/SO PIC16F1509T-I/SS PIC16F1509T-I/SSVAO PIC16LF1509-E/GZ PIC16LF1509-E/ML PIC16LF1509-E/P PIC16LF1509-E/SO PIC16LF1509-E/SS PIC16LF1509-I/GZ PIC16LF1509-I/ML PIC16LF1509-I/P PIC16LF1509-I/SO PIC16LF1509-I/SS PIC16LF1509T-I/GZ PIC16LF1509T-I/ML PIC16LF1509T-I/SO PIC16LF1509T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16F1509H/SSVAO, PIC16F1509 H/SSVAO
