Datasheet Microchip PIC24FJ64GA108 — Даташит
Производитель | Microchip |
Серия | PIC24FJ64GA108 |
Ideal for low power (<100nA standby current) and connectivity applications that benefit from the availability of multiple serial ports (3xI2C, 3xSPI), 4xUARTS, and 23 independent timers
Купить PIC24FJ64GA108 на РадиоЛоцман.Цены — от 72 до 923 ₽ 16 предложений от 16 поставщиков PIC PIC® 24F Microcontroller IC 16-Bit 32MHz 64KB (22K x 24) FLASH 80-TQFP (12x12) | |||
PIC24FJ64GA108-E/PT Microchip | 72 ₽ | ||
PIC24FJ64GA108-I/PT Microchip | 206 ₽ | ||
PIC24FJ64GA108T-I/PT Microchip | по запросу | ||
PIC24FJ64GA108-I/PT Microchip | по запросу |
PIC24FJ64GA108-I/PT | |
N | 1 |
Корпус | TQFP |
Количество выводов | 80 |
Parameters / Models | PIC24FJ64GA108-I/PT |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit PIC MCU |
CRC/Scan | Yes |
Cap. Touch Channels | 16 |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 3 |
Internal Oscillator | 8 MHz, 31 kHz |
Internal Voltage Reference, Bandgap | No |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 9 |
Max 16 Bit Digital Timers | 23 |
Max A/D Resolution, bits | 10 |
Max PWM Resolution, bits | 16 |
Max. CPU Speed MHz | 32 |
Рабочий диапазон температур, °C | от -40 до +85 |
Operation Voltage Min.(V) | 2 |
Peripheral Pin Select, PPS | Yes |
Pin count | 80 |
Размер памяти программ, Kbytes | 64 |
RAM, bytes | 16384 |
SPIв„ў | 3 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 4 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
PIC24FJ128GA106 PIC24FJ128GA108 PIC24FJ128GA110 PIC24FJ192GA106 PIC24FJ192GA108 PIC24FJ192GA110 PIC24FJ256GA106 PIC24FJ256GA108 PIC24FJ256GA110 PIC24FJ64GA106 PIC24FJ64GA110
Серия: PIC24FJ64GA108 (1)
