Datasheet Microchip PIC16F1704-E/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1704 |
Модель | PIC16F1704-E/ML |
PIC16F1704 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications.
Datasheet PIC16F1704, PIC16F1708, PIC16LF1704, PIC16LF1708
PDF, 5.9 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 452
14/20-Pin 8-Bit Advanced Analog Flash Microcontrollers
PIC16(L)F170X/171X
PDF, 449 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Cost Effective 8-Bit Intelligent Analog Flash Microcontrollers
Купить PIC16F1704-E/ML на РадиоЛоцман.Цены — от 39 до 423 ₽ 20 предложений от 12 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 7KB (4K x 14) FLASH 16-QFN (4x4) | |||
PIC16F1704-E/ML Microchip | 39 ₽ | ||
PIC16F1704-E/ML Microchip | 41 ₽ | ||
PIC16F1704-E/ML Microchip | 235 ₽ | ||
PIC16F1704-E/ML Microchip | по запросу |
This microcontroller delivers on-chip Op Amps, Core Independent Peripherals (CLC, COG and Zero Cross Detect) and Peripheral Pin Select, providing for increased design flexibility.
Корпус | QFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 3 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 16 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Number of Op Amps | 2 |
Package Width | 4x4x0.9mm |
Pin count | 14 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 512 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
PIC16F1703 PIC16F1705 PIC16F1707 PIC16F1708 PIC16F1709 PIC16F1713 PIC16F1716 PIC16F1717 PIC16F1718 PIC16F1719
Серия: PIC16F1704 (31)
- PIC16F1704-E/JQ PIC16F1704-E/ML PIC16F1704-E/MLVAO PIC16F1704-E/P PIC16F1704-E/SL PIC16F1704-E/SLVAO PIC16F1704-E/ST PIC16F1704-E/STVAO PIC16F1704-I/JQ PIC16F1704-I/ML PIC16F1704-I/MLVAO PIC16F1704-I/P PIC16F1704-I/SL PIC16F1704-I/SLVAO PIC16F1704-I/ST PIC16F1704T-E/ML PIC16F1704T-E/MLVAO PIC16F1704T-E/SL PIC16F1704T-E/SLVAO PIC16F1704T-E/ST PIC16F1704T-E/STVAO PIC16F1704T-I/JQ PIC16F1704T-I/ML PIC16F1704T-I/MLVAO PIC16F1704T-I/SL PIC16F1704T-I/SLVAO PIC16F1704T-I/ST PIC16F1704T-I/STVAO PIC16LF1704-E/JQ PIC16LF1704-I/JQ PIC16LF1704T-I/JQ
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1704E/ML, PIC16F1704 E/ML
