Datasheet Microchip PIC16F1704T-E/SL — Даташит
СерияPIC16F1704
МодельPIC16F1704T-E/SL
PIC16F1704 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications.
Datasheet PIC16F1704, PIC16F1708, PIC16LF1704, PIC16LF1708
PDF, 5.9 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 452
14/20-Pin 8-Bit Advanced Analog Flash Microcontrollers
PIC16(L)F170X/171X
PDF, 449 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Cost Effective 8-Bit Intelligent Analog Flash Microcontrollers
RISC Microcontroller, 8-Bit, FLASH, PIC CPU, 32MHz, CMOS, PDSO14
Akcel
PIC16F1704T-E/SL
This microcontroller delivers on-chip Op Amps, Core Independent Peripherals (CLC, COG and Zero Cross Detect) and Peripheral Pin Select, providing for increased design flexibility.
КорпусSOIC
ADC Input8
ADC with ComputationNo
Angular TimerNo
Архитектура8
CPU Type8-bit PIC MCU
CRCNo
Class B SupportNo
Complementary Waveform Generator / Complementary Output Generator1
Configurable Logic Cell3 CLC/CCL
Emulated EEPROM in Flash0 / HEF
High Voltage CapableNo
I2C1
Lead Count14
Math AcceleratorNo
Max 16-Bit Digital Timers1
Max 8-Bit Digital Timers4
Max ADC Resolution10 Bits
Max CPU Speed32 МГц
Max DAC Resolution8 Bits
Max PWM outputs8 including complementary
Количество компараторов2
Number of DACs1
Number of Op Amps2
Operation Voltage Max5.5 В
Operation Voltage Min1.8 В
PWM Max Resolution10 Bits
Package Width.150In(3.90mm)
Pin count14
Размер памяти программ7 KB
SPI1
SRAM512 Bytes
Temp Range Max125
Temp Range Min-40
UART1
Zero Cross detectYes
PIC16F1703 PIC16F1705 PIC16F1707 PIC16F1708 PIC16F1709 PIC16F1713 PIC16F1716 PIC16F1717 PIC16F1718 PIC16F1719
  • 8-bit Microcontrollers > PIC16 MCU
PIC16F1704TE/SL, PIC16F1704T E/SL
На английском языке: Datasheet Microchip PIC16F1704T-E/SL
