Datasheet Microchip PIC16F1705-I/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1705 |
Модель | PIC16F1705-I/ML |
PIC16F1705 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications.
Datasheet PIC16F1705, PIC16F1709, PIC16LF1705, PIC16LF1709
PDF, 6.0 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 454
Cost-Effective 8-Bit Intelligent Analog Flash Microcontrollers
PIC16(L)F170X/171X
PDF, 449 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Cost Effective 8-Bit Intelligent Analog Flash Microcontrollers
Купить PIC16F1705-I/ML на РадиоЛоцман.Цены — от 63 до 243 ₽ 20 предложений от 12 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 14KB (8K x 14) FLASH 16-QFN (4x4) | |||
PIC16F1705-I/ML Microchip | 63 ₽ | ||
PIC16F1705-I/ML Microchip | 66 ₽ | ||
PIC16F1705-I/ML Microchip | 69 ₽ | ||
PIC16F1705-I/ML Microchip | от 243 ₽ |
This microcontroller delivers on-chip Op Amps, Core Independent Peripherals (CLC, COG and Zero Cross Detect) and Peripheral Pin Select, providing for increased design flexibility.
Корпус | QFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 3 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 16 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Number of Op Amps | 2 |
Package Width | 4x4x0.9mm |
Pin count | 14 |
Размер памяти программ | 14 KB |
SPI | 1 |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
PIC16F1703 PIC16F1704 PIC16F1707 PIC16F1708 PIC16F1709 PIC16F1713 PIC16F1716 PIC16F1717 PIC16F1718 PIC16F1719
Серия: PIC16F1705 (31)
- PIC16F1705-E/ML PIC16F1705-E/P PIC16F1705-E/SL PIC16F1705-E/ST PIC16F1705-E/STVAO PIC16F1705-I/ML PIC16F1705-I/MLVAO PIC16F1705-I/P PIC16F1705-I/SL PIC16F1705-I/ST PIC16F1705-I/STVAO PIC16F1705T-E/ML PIC16F1705T-E/SL PIC16F1705T-E/ST PIC16F1705T-E/STVAO PIC16F1705T-I/ML PIC16F1705T-I/MLVAO PIC16F1705T-I/SL PIC16F1705T-I/ST PIC16F1705T-I/STVAO PIC16LF1705-E/ML PIC16LF1705-E/P PIC16LF1705-E/SL PIC16LF1705-E/ST PIC16LF1705-I/ML PIC16LF1705-I/P PIC16LF1705-I/SL PIC16LF1705-I/ST PIC16LF1705T-I/ML PIC16LF1705T-I/SL PIC16LF1705T-I/ST
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1705I/ML, PIC16F1705 I/ML
