Datasheet Microchip PIC16F1707-I/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1707 |
Модель | PIC16F1707-I/ML |
PIC16F1707 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications.
Datasheet PIC16F1703, PIC16F1707, PIC16LF1703, PIC16LF1707
PDF, 4.5 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 338
14/20-Pin 8-Bit Advanced Analog Flash Microcontrollers
PIC16(L)F170X/171X
PDF, 449 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Cost Effective 8-Bit Intelligent Analog Flash Microcontrollers
Купить PIC16F1707-I/ML на РадиоЛоцман.Цены — от 67 до 99 ₽ 9 предложений от 9 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 3.5KB (2K x 14) FLASH 20-QFN (4x4) | |||
PIC16F1707-I/ML Microchip | 67 ₽ | ||
PIC16F1707-I/ML Microchip | 68 ₽ | ||
PIC16F1707-I/ML Microchip | 79 ₽ | ||
PIC16F1707-I/ML Microchip | по запросу |
This microcontroller delivers on-chip Op Amps, Core Independent Peripherals (COG and Zero Cross Detect) and Peripheral Pin Select, providing for increased design flexibility.
Корпус | QFN |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 32 МГц |
Max PWM outputs | 2 including complementary |
Number of Op Amps | 2 |
Package Width | 4x4x0.9mm |
Pin count | 20 |
Размер памяти программ | 3.5 KB |
SPI | 1 |
SRAM | 256 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
Zero Cross detect | Yes |
PIC16F1703 PIC16F1704 PIC16F1705 PIC16F1708 PIC16F1709 PIC16F1713 PIC16F1716 PIC16F1717 PIC16F1718 PIC16F1719
Серия: PIC16F1707 (12)
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1707I/ML, PIC16F1707 I/ML
