Datasheet Microchip PIC16F1708-E/GZ — Даташит
Производитель | Microchip |
Серия | PIC16F1708 |
Модель | PIC16F1708-E/GZ |
PIC16F1708 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications
Datasheet PIC16F1704, PIC16F1708, PIC16LF1704, PIC16LF1708
PDF, 5.9 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 452
14/20-Pin 8-Bit Advanced Analog Flash Microcontrollers
Купить PIC16F1708-E на РадиоЛоцман.Цены — от 44 до 5 087 ₽ 37 предложений от 24 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 7KB (4K x 14) FLASH 20-SSOP | |||
PIC16F1708-I/ML Microchip | 44 ₽ | ||
PIC16F1708-I/ML Microchip | 45 ₽ | ||
PIC16F1708-I/SS Microchip | 101 ₽ | ||
PIC16F1708-I/SS Microchip | от 266 ₽ |
Корпус | UQFN |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 3 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Number of Op Amps | 2 |
Package Width | 4x4x0.5mm |
Pin count | 20 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 512 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1708 (32)
- PIC16F1708-E/GZ PIC16F1708-E/ML PIC16F1708-E/P PIC16F1708-E/SO PIC16F1708-E/SS PIC16F1708-E/SSVAO PIC16F1708-I/GZ PIC16F1708-I/ML PIC16F1708-I/P PIC16F1708-I/SO PIC16F1708-I/SS PIC16F1708T-E/ML PIC16F1708T-E/SS PIC16F1708T-E/SSVAO PIC16F1708T-I/GZ PIC16F1708T-I/ML PIC16F1708T-I/SO PIC16F1708T-I/SS PIC16LF1708-E/GZ PIC16LF1708-E/ML PIC16LF1708-E/P PIC16LF1708-E/SO PIC16LF1708-E/SS PIC16LF1708-I/GZ PIC16LF1708-I/ML PIC16LF1708-I/P PIC16LF1708-I/SO PIC16LF1708-I/SS PIC16LF1708T-I/GZ PIC16LF1708T-I/ML PIC16LF1708T-I/SO PIC16LF1708T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16F1708E/GZ, PIC16F1708 E/GZ
