Datasheet Microchip PIC16F1718T-I/MLVAO — Даташит
Производитель | Microchip |
Серия | PIC16F1718 |
Модель | PIC16F1718T-I/MLVAO |
PIC16F1718 combines Intelligent Analog integration with low cost and extreme low power (XLP) to suit a variety of general purpose applications.
PIC16(L)F170X/171X
PDF, 449 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Cost Effective 8-Bit Intelligent Analog Flash Microcontrollers
Datasheet PIC16F1717, PIC16F1718, PIC16F1719, PIC16LF1717, PIC16LF1718, PIC16LF1719
PDF, 6.8 Мб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 486
Cost-Effective 8-Bit Intelligent Analog Flash Microcontrollers
PIC16(L)F1717/8/9 Cost Effective 8-Bit Intelligent Analog Flash MCU Data Sheet
PDF, 6.5 Мб, Файл опубликован: 2 дек 2015
Купить PIC16F1718T-I на РадиоЛоцман.Цены — от 88 до 347 ₽ 20 предложений от 11 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 28-UQFN (4x4) | |||
PIC16F1718T-I/SS Microchip | 88 ₽ | ||
PIC16F1718T-I/ML Microchip | от 124 ₽ | ||
PIC16F1718T-I/MV Microchip | 127 ₽ | ||
PIC16F1718T-I/SS Microchip | от 182 ₽ |
This microcontroller delivers on-chip Op Amps, Core Independent Peripherals (CLC, COG, NCO and Zero Cross Detect) and Peripheral Pin Select, providing for increased design flexibility.
Корпус | QFN |
ADC Input | 17 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 4 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Количество компараторов | 2 |
Number of DACs | 2 |
Number of Op Amps | 2 |
Numerically Controlled Oscillator | 1 |
Package Width | 6x6x0.9mm |
Pin count | 28 |
Размер памяти программ | 28 KB |
SPI | 1 |
SRAM | 2048 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
PIC16F1703 PIC16F1704 PIC16F1705 PIC16F1707 PIC16F1708 PIC16F1709 PIC16F1713 PIC16F1716 PIC16F1717 PIC16F1719
Серия: PIC16F1718 (31)
- PIC16F1718-E/ML PIC16F1718-E/MV PIC16F1718-E/SO PIC16F1718-E/SP PIC16F1718-E/SS PIC16F1718-I/ML PIC16F1718-I/MLVAO PIC16F1718-I/MV PIC16F1718-I/SO PIC16F1718-I/SP PIC16F1718-I/SS PIC16F1718T-E/MV PIC16F1718T-I/ML PIC16F1718T-I/MLVAO PIC16F1718T-I/MV PIC16F1718T-I/SO PIC16F1718T-I/SS PIC16LF1718-E/ML PIC16LF1718-E/MV PIC16LF1718-E/SO PIC16LF1718-E/SP PIC16LF1718-E/SS PIC16LF1718-I/ML PIC16LF1718-I/MV PIC16LF1718-I/SO PIC16LF1718-I/SP PIC16LF1718-I/SS PIC16LF1718T-I/ML PIC16LF1718T-I/MV PIC16LF1718T-I/SO PIC16LF1718T-I/SS
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1718TI/MLVAO, PIC16F1718T I/MLVAO
