Datasheet Microchip PIC16F1764-E/SLVAO — Даташит
СерияPIC16F1764
МодельPIC16F1764-E/SLVAO
PIC16(L)F176X microcontrollers combine intelligent analog integration with digital peripherals to suit a variety of functions and applications.
Datasheet PIC16F1764, PIC16F1765, PIC16F1768, PIC16F1769, PIC16LF1764, PIC16LF1765, PIC16LF1768, PIC16LF1769
PDF, 9.6 Мб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 568
14/20-Pin, 8-Bit Flash Microcontrollers
PIC16(L)F1764/5/8/9 14/20-Pin, 8-Bit Flash MCU Data Sheet
PDF, 7.9 Мб, Файл опубликован: 5 мар 2018
Элитан
PIC16F1764-E/SLVAO
721 ₽
These 14/20-pin devices provide features like 10-bit A/D, op amps, zero cross detect, high current IOs, programmable ramp generator: (slope compensation & ramp generation), communication, peripheral pin select and other key peripherals that make this family appealing in applications looking for design flexibility.
КорпусSOIC
ADC Input8
ADC with ComputationNo
Angular TimerNo
Архитектура8
CPU Type8-bit PIC MCU
CRCNo
Class B SupportNo
Complementary Waveform Generator / Complementary Output Generator1
Configurable Logic Cell3 CLC/CCL
Data Signal Modulator1
Emulated EEPROM in Flash0 / HEF
Hardware Limit Timer3
High Voltage CapableNo
I2C1
Lead Count14
Math AcceleratorNo
Max 16-Bit Digital Timers3
Max 8-Bit Digital Timers4
Max ADC Resolution10 Bits
Max CPU Speed32 МГц
Max DAC Resolution10 Bits
Max PWM outputs6 including complementary
Количество компараторов2
Number of DACs2
Number of Op Amps1
Operation Voltage Max5.5 В
Operation Voltage Min1.8 В
PWM Max Resolution16 Bits
Package Width.150In(3.90mm)
Pin count14
Размер памяти программ7 KB
SPI1
SRAM512 Bytes
Slope Compensation / Programmable Ramp GeneratorYes
Temp Range Max125
Temp Range Min-40
UART1
Zero Cross detectYes
PIC16F1765 PIC16F1768 PIC16F1769
  • 8-bit Microcontrollers > PIC16 MCU
PIC16F1764E/SLVAO, PIC16F1764 E/SLVAO
На английском языке: Datasheet Microchip PIC16F1764-E/SLVAO
