Datasheet Microchip ATmega324PB — Даташит
Производитель | Microchip |
Серия | ATmega324PB |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 32kB ISP flash memory with read-while-write capabilities, 1kB EEPROM, 2kB SRAM, 39 general purpose I/O lines, 32 general purpose working registers, five flexible timer/counters with compare modes, internal and external interrupts, three USARTs with wake-up on start of transmission, two byte-oriented 2-wire serial interface, two SPI serial ports, one 8-channel 10-bit ADC with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, a JTAG (IEEE 1149
ATmega324PB - Complete Datasheet
PDF, 3.5 Мб, Файл опубликован: 30 июн 2017
ATmega324PB - Summary Datasheet
PDF, 242 Кб, Файл опубликован: 30 июн 2017
Купить ATmega324PB на РадиоЛоцман.Цены — от 108 до 454 ₽ 34 предложений от 19 поставщиков Микроконтроллер 8-бит ATmega 32 кБ Флэш-память 2 кБ Статическое ОЗУ 20 МГц TQFP-44 | |||
ATMEGA324PB-AUR Atmel | 108 ₽ | ||
ATMEGA324PB-AUR Atmel | 139 ₽ | ||
ATMEGA324P-B15AZ Microchip | 328 ₽ | ||
ATMEGA324PB-AN Microchip | по запросу |
ATMEGA324PB-ABT | ATMEGA324PB-ABTVAO | ATMEGA324PB-AN | ATMEGA324PB-ANR | ATMEGA324PB-AU | ATMEGA324PB-AUR | ATMEGA324PB-MBT | ATMEGA324PB-MBTVAO | ATMEGA324PB-MN | ATMEGA324PB-MNR | ATMEGA324PB-MU | ATMEGA324PB-MUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | TQFP | TQFP | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN | VQFN | VQFN |
Parameters / Models | ATMEGA324PB-ABT | ATMEGA324PB-ABTVAO | ATMEGA324PB-AN | ATMEGA324PB-ANR | ATMEGA324PB-AU | ATMEGA324PB-AUR | ATMEGA324PB-MBT | ATMEGA324PB-MBTVAO | ATMEGA324PB-MN | ATMEGA324PB-MNR | ATMEGA324PB-MU | ATMEGA324PB-MUR |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
Hardware Touch Peripheral | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC |
High Voltage Capable | No | No | No | No | No | No | No | No | No | No | No | No |
I2C | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 |
Math Accelerator | No | No | No | No | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Max PWM outputs, including complementary | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 10x10x1mm | 10x10x1mm | 10x10x1mm | 10x10x1mm | 10x10x1mm | 10x10x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No | No | No | No |
Pin count | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 |
Размер памяти программ, KB | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
SPI | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
SRAM, Bytes | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 |
Temp Range Max | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Zero Cross detect | No | No | No | No | No | No | No | No | No | No | No | No |
Серия: ATmega324PB (12)
- Microcontrollers > 8-bit Microcontrollers
