Datasheet Microchip ATmega328PB — Даташит
Производитель | Microchip |
Серия | ATmega328PB |
The high-performance Microchip's ATmega328PB is an 8-bit AVR® RISC-based microcontroller (MCU) with picoPower® technology
ATmega328PB - Complete Datasheet
PDF, 4.1 Мб, Файл опубликован: 22 фев 2018
ATmega328PB - Summary Datasheet
PDF, 172 Кб, Файл опубликован: 31 май 2017
Купить ATmega328PB на РадиоЛоцман.Цены — от 82 до 3 601 ₽ 45 предложений от 21 поставщиков Микроконтроллер 8-бит 32Кбайт Флэш-память электропитание 5В 32 VFQFN | |||
ATMEGA328PB-AU Microchip | 82 ₽ | ||
ATMEGA328PB-MURES Atmel | 85 ₽ | ||
ATMEGA328PB-AU Microchip | от 99 ₽ | ||
ATMEGA328PB-MUR | от 338 ₽ |
ATMEGA328PB-AN | ATMEGA328PB-ANR | ATMEGA328PB-AU | ATMEGA328PB-AUR | ATMEGA328PB-MN | ATMEGA328PB-MNR | ATMEGA328PB-MU | ATMEGA328PB-MUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN |
Parameters / Models | ATMEGA328PB-AN | ATMEGA328PB-ANR | ATMEGA328PB-AU | ATMEGA328PB-AUR | ATMEGA328PB-MN | ATMEGA328PB-MNR | ATMEGA328PB-MU | ATMEGA328PB-MUR |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
Hardware Touch Peripheral | PTC | PTC | PTC | PTC | PTC | PTC | PTC | PTC |
High Voltage Capable | No | No | No | No | No | No | No | No |
I2C | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Math Accelerator | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Max PWM outputs, including complementary | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 5x5x0.9mm | 5x5x0.9mm | 5x5x0.9mm | 5x5x0.9mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No |
Pin count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Размер памяти программ, KB | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
SPI | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
SRAM, Bytes | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 |
Temp Range Max | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Zero Cross detect | No | No | No | No | No | No | No | No |
Серия: ATmega328PB (8)
- Microcontrollers > 8-bit Microcontrollers
