Datasheet Microchip ATxmega16A4U — Даташит
Производитель | Microchip |
Серия | ATxmega16A4U |
Low power, high performance 8/16-bit AVR microcontroller featuring 16KB self-programming flash program memory, 4KB boot code section, 2KB SRAM, 1024-Byte EEPROM, external bus interface, 4-channel DMA controller, 8-channel event system, and up to 32 MIPS throughput at 32MHz
Atmel AVR XMEGA AU - Complete Datasheet
PDF, 7.6 Мб, Файл опубликован: 1 апр 2013
ATxmega16A4U/32A4U/64A4U/128A4U Datasheet
PDF, 24.7 Мб, Файл опубликован: 5 май 2017
Купить ATxmega16A4U на РадиоЛоцман.Цены — от 103 до 2 011 ₽ 28 предложений от 20 поставщиков AVR AVR® XMEGA® A4U Microcontroller IC 8/16-Bit 32MHz 16KB (8K x 16) FLASH 44-VQFN (7x7) | |||
ATxmega16A4U-AU Atmel | 103 ₽ | ||
ATXMEGA16A4U-MH Microchip | 119 ₽ | ||
ATXMEGA16A4U-MHR Atmel | по запросу | ||
ATXMEGA16A4U-AUR Microchip | по запросу |
ATXMEGA16A4U-AN | ATXMEGA16A4U-ANR | ATXMEGA16A4U-AU | ATXMEGA16A4U-AUR | ATXMEGA16A4U-CU | ATXMEGA16A4U-CUR | ATXMEGA16A4U-MH | ATXMEGA16A4U-MHR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | TQFP | TQFP | TQFP | TQFP | VFBGA | VFBGA | VQFN | VQFN |
Parameters / Models | ATXMEGA16A4U-AN | ATXMEGA16A4U-ANR | ATXMEGA16A4U-AU | ATXMEGA16A4U-AUR | ATXMEGA16A4U-CU | ATXMEGA16A4U-CUR | ATXMEGA16A4U-MH | ATXMEGA16A4U-MHR |
ADC Input | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
ADC with Computation | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
High Voltage Capable | No | No | No | No | No | No | No | No |
I2C | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 44 | 44 | 44 | 44 | 49 | 49 | 44 | 44 |
Math Accelerator | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Max ADC Resolution, Bits | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
Max CPU Speed, МГц | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Max DAC Resolution, Bits | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
Max PWM outputs, including complementary | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
Количество компараторов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Number of USB Modules | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 |
Operation Voltage Min, В | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
Package Width | 10x10x1mm | 10x10x1mm | 10x10x1mm | 10x10x1mm | 5x5x1mm | 5x5x1mm | 7x7x1mm | 7x7x1mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No |
Pin count | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 |
Размер памяти программ, KB | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
SPI | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
SRAM, Bytes | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 | 2048 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Zero Cross detect | No | No | No | No | No | No | No | No |
Серия: ATxmega16A4U (8)
- Microcontrollers > 8-bit Microcontrollers
