Datasheet Microchip ATXMEGA32D4-MHR — Даташит
Производитель | Microchip |
Серия | ATxmega32D4 |
Модель | ATXMEGA32D4-MHR |
The high-performance, low-power 8/16-bit AVR XMEGA microcontroller combines 32KB ISP flash memory (4KB boot code section) with read-while-write capabilities, 1KB EEPROM, 4KB SRAM, four-channel event system, a programmable multi-level interrupt controller, 34 general purpose I/O lines, a 16-bit real time counter, four flexible 16-bit timer/counters with compare modes and PWM, two USARTs, two Two-Wire Interfaces (TWIs), two Serial Peripheral Interfaces (SPIs), one 12-channel/12-bit A/D converter with optional differential input with programmable gain, two analog comparators with window mode, a programmable watchdog timer with separate internal oscillator, accurate internal oscillators with PLL and prescaler, and programmable brown-out detection
Купить ATXMEGA32D4-MHR на РадиоЛоцман.Цены — от 122 до 6 762 ₽ 17 предложений от 11 поставщиков AVR AVR® XMEGA® D4 Microcontroller IC 8/16-Bit 32MHz 32KB (16K x 16) FLASH 44-VQFN (7x7) | |||
ATXMEGA32D4-MHR Microchip | 122 ₽ | ||
ATXMEGA32D4-MHR Atmel | 239 ₽ | ||
ATXMEGA32D4-MHR Atmel | 243 ₽ | ||
ATXMEGA32D4-MHR Microchip | 252 ₽ |
Корпус | VQFN |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 1024 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | Yes |
Lead Count | 44 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 32 МГц |
Max PWM outputs | 14 including complementary |
Количество компараторов | 2 |
Operation Voltage Max | 3.6 В |
Operation Voltage Min | 1.6 В |
Package Width | 7x7x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 44 |
Размер памяти программ | 32 KB |
SPI | 4 |
SRAM | 4096 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
- Microcontrollers > 8-bit Microcontrollers
ATXMEGA32D4MHR, ATXMEGA32D4 MHR
