Datasheet Microchip ATTINY24A-CCU — Даташит
Производитель | Microchip |
Серия | ATtiny24A |
Модель | ATTINY24A-CCU |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 2KB ISP flash memory, 128B EEPROM, 128B SRAM, 12 general purpose I/O lines, 32 general purpose working registers, an 8-bit timer/counter with two PWM channels, a 16-bit timer/counter with two PWM channels, internal and external interrupts, an 8-channel 10-bit A/D converter, programmable gain stage (1x, 20x) for 12 differential ADC channel pairs, programmable watchdog timer with internal oscillator, internal calibrated oscillator, and four software selectable power saving modes
Datasheet ATtiny24A, ATtiny44A. Appendix A. Specification at 105°C
PDF, 3.3 Мб, Файл опубликован: 1 авг 2011, Страниц: 60
8-bit Microcontroller with 2K/4K Bytes In-System Programmable Flash
Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Appendix B. Specification at 125°C
PDF, 4.5 Мб, Файл опубликован: 1 окт 2013, Страниц: 85
8-bit AVR Microcontroller with 2K/4K/8K Bytes In-System Programmable Flash
Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Complete
PDF, 9.6 Мб, Файл опубликован: 1 июн 2012, Страниц: 286
8-bit Microcontroller with 2K/4K/8K Bytes In-System Programmable Flash
Datasheet Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Summary
PDF, 707 Кб, Файл опубликован: 1 июн 2012, Страниц: 22
Купить ATTINY24A-CCU на РадиоЛоцман.Цены — от 48 до 301 ₽ 22 предложений от 14 поставщиков AVR AVR® ATtiny Microcontroller IC 8-Bit 20MHz 2KB (1K x 16) FLASH 15-UFBGA (3x3) | |||
ATTINY24A-CCU Microchip | 48 ₽ | ||
ATTINY24A-CCU Microchip | 79 ₽ | ||
ATTINY24A-CCU Microchip | по запросу | ||
Корпус | UFBGA |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 128 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 15 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 4 including complementary |
Количество компараторов | 1 |
Package Width | 3x3x0.6mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 14 |
Размер памяти программ | 2 KB |
SPI | 1 |
SRAM | 128 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: ATtiny24A (17)
- Microcontrollers > 8-bit Microcontrollers
ATTINY24ACCU, ATTINY24A CCU
