Datasheet Microchip ATMEGA64A-MN — Даташит
Производитель | Microchip |
Серия | ATmega64A |
Модель | ATMEGA64A-MN |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 64KB ISP flash memory with read-while-write capabilities, 2KB EEPROM, 4KB SRAM, 53 general purpose I/O lines, 32 general purpose working registers, a real time counter, four flexible timer/counters with compare modes and PWM, two USARTs, a byte-oriented 2-wire serial interface, an 8-channel/10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
Datasheet ATmega64A - Complete
PDF, 6.2 Мб, Файл опубликован: 10 дек 2016, Страниц: 505
Atmel ATmega64A is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture
Datasheet ATmega64A - Summary
PDF, 333 Кб, Файл опубликован: 10 дек 2016, Страниц: 20
8-bit AVR Micrcontroller
Купить ATMEGA64A-MN на РадиоЛоцман.Цены — от 279 до 1 240 ₽ 18 предложений от 14 поставщиков IC: микроконтроллер AVR; EEPROM: 2kБ; SRAM: 4kБ; Flash: 64kБ; VQFN64 | |||
ATMEGA64A-MN Microchip | 279 ₽ | ||
ATMEGA64A-MN Microchip | 281 ₽ | ||
ATMEGA64A-MN Atmel | по запросу | ||
ATMEGA64A-MN Microchip | по запросу |
Корпус | VQFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 2048 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 64 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 2 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 16 МГц |
Max PWM outputs | 7 including complementary |
Количество компараторов | 1 |
Operation Voltage Min | 2.7 В |
Package Width | 9x9x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 64 |
Размер памяти программ | 64 KB |
SPI | 1 |
SRAM | 4096 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
Серия: ATmega64A (8)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA64AMN, ATMEGA64A MN
