Datasheet Microchip PIC16F18323T-E/ST — Даташит
Производитель | Microchip |
Серия | PIC16F18323 |
Модель | PIC16F18323T-E/ST |
PIC16F18323 microcontrollers feature Analog, Core Independent Peripherals and communication peripherals, combined with Extreme Low Power (XLP) for wide range of general purpose and low power applications
PIC16(L)F18313/18323 Data Sheet
PDF, 5.8 Мб, Файл опубликован: 21 ноя 2017
Купить PIC16F18323T-E на РадиоЛоцман.Цены — от 48 до 177 ₽ 21 предложений от 12 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 3.5KB (2K x 14) FLASH 16-UQFN (4x4) | |||
PIC16F18323T-I/SL Microchip | 48 ₽ | ||
PIC16F18323T-I/ML Microchip | 63 ₽ | ||
PIC16F18323T-I/ST Microchip | 177 ₽ | ||
PIC16F18323T-I/SL Microchip | по запросу |
Корпус | TSSOP |
ADC Input | 11 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 2 CLC/CCL |
Data Signal Modulator | 2 |
Emulated EEPROM in Flash | 256 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 14 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | 4.4mm |
Pin count | 14 |
Размер памяти программ | 3.5 KB |
SPI | 1 |
SRAM | 256 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F18323 (47)
- PIC16F18323-E/JQ PIC16F18323-E/P PIC16F18323-E/SL PIC16F18323-E/SLVAO PIC16F18323-E/ST PIC16F18323-E/STVAO PIC16F18323-I/JQ PIC16F18323-I/P PIC16F18323-I/PREL PIC16F18323-I/SL PIC16F18323-I/SLVAO PIC16F18323-I/ST PIC16F18323-I/STVAO PIC16F18323T-E/JQ PIC16F18323T-E/SL PIC16F18323T-E/SLVAO PIC16F18323T-E/ST PIC16F18323T-E/STVAO PIC16F18323T-I/JQ PIC16F18323T-I/SL PIC16F18323T-I/SLVAO PIC16F18323T-I/ST PIC16F18323T-I/STVAO PIC16LF18323-E/JQ PIC16LF18323-E/P PIC16LF18323-E/SL PIC16LF18323-E/SLVAO PIC16LF18323-E/ST PIC16LF18323-I/JQ PIC16LF18323-I/P PIC16LF18323-I/SL PIC16LF18323-I/ST PIC16LF18323-I/ST024 PIC16LF18323-I/ST025 PIC16LF18323-I/ST028 PIC16LF18323-I/STC02 PIC16LF18323T-E/SL PIC16LF18323T-E/SLVAO PIC16LF18323T-I/JQ PIC16LF18323T-I/SL PIC16LF18323T-I/SLC01 PIC16LF18323T-I/ST PIC16LF18323T-I/ST024 PIC16LF18323T-I/ST025 PIC16LF18323T-I/ST026 PIC16LF18323T-I/ST028 PIC16LF18323T-I/STC02
- Microcontrollers > 8-bit Microcontrollers
PIC16F18323TE/ST, PIC16F18323T E/ST
