Datasheet Microchip PIC16F18325T-E/ST — Даташит
Производитель | Microchip |
Серия | PIC16F18325 |
Модель | PIC16F18325T-E/ST |
PIC16F18325 microcontrollers feature Analog, Core Independent Peripherals and communication peripherals, combined with Extreme Low Power (XLP) for wide range of general purpose and low power applications.
Datasheet PIC16(L)F18325/18345
PDF, 6.1 Мб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 498
Full-Featured, Low Pin Count Microcontrollers with XLP
Datasheet PIC16F18325/18345
PDF, 324 Кб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 18
Full-Featured, Low Pin Count, High-Temperature Microcontrollers
PIC16(L)F18325/18345 Full-Featured, Low Pin Count MCUs with XLP Data Sheet
PDF, 6.3 Мб, Файл опубликован: 25 июл 2017
PIC16F18325/18345 Full-Featured, Low Pin Count, High-Temperature MCUs
PDF, 321 Кб, Файл опубликован: 20 апр 2018
Купить PIC16F18325T-E на РадиоЛоцман.Цены — от 60 до 218 ₽ 18 предложений от 9 поставщиков PIC PIC® XLPTM16F, Functional Safety (FuSa) Microcontroller IC 8-Bit 32MHz 14KB (8K x 14) FLASH 14-SOIC | |||
PIC16F18325T-I/SL Microchip | 60 ₽ | ||
PIC16F18325T-I/ML Microchip | 75 ₽ | ||
PIC16F18325T-I/SL Microchip | от 218 ₽ | ||
PIC16F18325T-I/SL Microchip | по запросу |
The Peripheral Pin Select (PPS) functionality enables pin mapping when using the digital peripherals (CLC, CWG, CCP, PWM and communications) to add flexibility to the application design. Demonstration Platform Internet of Things Sensor Badge with interactive control via motion, multiple sensors, RGB LEDs and bluetooth communication. www.microchip.com/iotsensorbadge
Корпус | TSSOP |
ADC Input | 11 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | Yes |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 4 |
Emulated EEPROM in Flash | 256 |
High Voltage Capable | No |
I2C | 2 |
Lead Count | 14 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 14 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Package Width | 4.4mm |
Pin count | 14 |
Размер памяти программ | 14 KB |
SPI | 2 |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F18325 (35)
- PIC16F18325-E/7NVAO PIC16F18325-E/JQ PIC16F18325-E/P PIC16F18325-E/PREL PIC16F18325-E/SL PIC16F18325-E/SLVAO PIC16F18325-E/ST PIC16F18325-I/JQ PIC16F18325-I/JQVAO PIC16F18325-I/P PIC16F18325-I/SL PIC16F18325-I/ST PIC16F18325-I/STVAO PIC16F18325T-E/7NVAO PIC16F18325T-E/SLVAO PIC16F18325T-E/ST PIC16F18325T-E/STVAO PIC16F18325T-I/JQ PIC16F18325T-I/JQVAO PIC16F18325T-I/SL PIC16F18325T-I/ST PIC16F18325T-I/STVAO PIC16LF18325-E/JQ PIC16LF18325-E/JQVAO PIC16LF18325-E/P PIC16LF18325-E/SL PIC16LF18325-E/ST PIC16LF18325-I/JQ PIC16LF18325-I/P PIC16LF18325-I/SL PIC16LF18325-I/ST PIC16LF18325T-E/JQVAO PIC16LF18325T-I/JQ PIC16LF18325T-I/SL PIC16LF18325T-I/ST
- 8-bit Microcontrollers > PIC16 MCU
PIC16F18325TE/ST, PIC16F18325T E/ST
