Datasheet Microchip ATMEGA2561-16MUA0 — Даташит
Производитель | Microchip |
Серия | ATmega2561 |
Модель | ATMEGA2561-16MUA0 |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 256KB ISP flash memory, 8KB SRAM, 4KB EEPROM, 86 general purpose I/O lines, 32 general purpose working registers, real time counter, six flexible timer/counters with compare modes, PWM, 4 USARTs, byte oriented 2-wire serial interface, 8-channel 10-bit A/D converter, and a JTAG interface for on-chip debugging
Datasheet ATmega640/V-1280/V-1281/V-2560/V-2561/V - Complete
PDF, 8.8 Мб, Файл опубликован: 1 фев 2014, Страниц: 435
8-bit Atmel Microcontroller with 16/32/64KB In-System Programmable Flash
ATmega640/1280/1281/2560/2561 - Summary Datasheet
PDF, 1.0 Мб, Файл опубликован: 1 фев 2014
Купить ATMEGA2561 на РадиоЛоцман.Цены — от 72 до 3 176 ₽ 48 предложений от 29 поставщиков Контроллеры.Тип: Микроконтроллер 8 бит серии ATmega256xИнтерфейс: 2-Wire, SPI, USARTКоличество: вх./ вых. - 54 I/O; таймеров - 6Память: программная (Flash) - 256... | |||
ATMEGA2561-16AI Microchip | 72 ₽ | ||
ATmega2561-16AU Atmel | 246 ₽ | ||
ATMEGA2561-16AU | 999 ₽ | ||
ATMEGA2561-16AU | 1 223 ₽ |
Корпус | VQFN |
Количество выводов | 64 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU | 8-bit AVR |
CRC/Scan | No |
EEPROM / HEF | 4096 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 4 |
Max 8 Bit Digital Timers | 2 |
Max A/D Resolution | 10 bits |
Max. CPU Speed MHz | 16 |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 1.8 |
Peripheral Pin Select | No PPS |
Pin count | 64 |
Размер памяти программ | 256 Kbytes |
RAM | 8192 bytes |
SPI | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
UART | 2 |
Zero Cross detect | No |
ATmega1280 ATmega1280V ATmega1281 ATmega2560 ATmega2560V ATmega2561V ATmega640 ATmega640V
Серия: ATmega2561 (9)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA256116MUA0, ATMEGA2561 16MUA0
