Datasheet Microchip ATmega169PA — Даташит
Производитель | Microchip |
Серия | ATmega169PA |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 16KB ISP flash memory with read-while-write capabilities, 512B EEPROM, 1KB SRAM, 54/69 general purpose I/O lines, 32 general purpose working registers, a JTAG interface for boundary-scan and on-chip debugging/programming, a complete on-chip LCD controller with internal contrast control, three flexible timer/counters with compare modes, internal and external interrupts,serial programmable USART, a universal serial interface (USI) with start condition detector, an 8-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, SPI serial port, and five software selectable power saving modes
8-bit Atmel Microcontroller with 16/32/64KB In-System Programmable Flash
Купить ATmega169PA на РадиоЛоцман.Цены — от 137 до 1 020 ₽ 41 предложений от 25 поставщиков 8-битные микроконтроллеры AVR LCD 16KB FLSH EE 512B 1KB SRAM-16MHZ | |||
ATMEGA169PA-AU Atmel | 137 ₽ | ||
ATMEGA169PA-MNR Microchip | по запросу | ||
ATMEGA169PA-MCHR Atmel | по запросу |
ATMEGA169PA-AN | ATMEGA169PA-ANR | ATMEGA169PA-AU | ATMEGA169PA-AUR | ATMEGA169PA-MCH | ATMEGA169PA-MCHR | ATMEGA169PA-MN | ATMEGA169PA-MNR | ATMEGA169PA-MU | ATMEGA169PA-MUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
Корпус | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN | VQFN | VQFN |
Parameters / Models | ATMEGA169PA-AN | ATMEGA169PA-ANR | ATMEGA169PA-AU | ATMEGA169PA-AUR | ATMEGA169PA-MCH | ATMEGA169PA-MCHR | ATMEGA169PA-MN | ATMEGA169PA-MNR | ATMEGA169PA-MU | ATMEGA169PA-MUR |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 |
High Voltage Capable | No | No | No | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
Math Accelerator | No | No | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
Max PWM outputs, including complementary | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 14x14x1mm | 14x14x1mm | 14x14x1mm | 14x14x1mm | 7x7x1mm | 7x7x1mm | 9x9x1mm | 9x9x1mm | 9x9x1mm | 9x9x1mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No | No |
Pin count | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
Размер памяти программ, KB | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
SPI | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
SRAM, Bytes | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
Segmented LCD | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Zero Cross detect | No | No | No | No | No | No | No | No | No | No |
ATmega169A ATmega3290A ATmega3290PA ATmega329A ATmega329PA ATmega6490A ATmega6490P ATmega649A ATmega649P
- Microcontrollers > 8-bit Microcontrollers
