Datasheet Microchip ATtiny861A — Даташит
Производитель | Microchip |
Серия | ATtiny861A |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 8KB flash memory, 512B EEPROM, 512-Byte SRAM, 16 general purpose I/O lines, 32 general purpose working registers, an 8-bit timer/counter with compare modes, an 8-bit high speed timer/counter, a universal serial interface (USI), internal and external Interrupts, an 11-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, and four software selectable power saving modes
Appendix A - ATtiny261A Specification at 125?C Datasheet
PDF, 1.5 Мб, Файл опубликован: 10 дек 2016
ATtiny261A/461A/861A - Complete Datasheet
PDF, 8.9 Мб, Файл опубликован: 1 май 2011
ATtiny261A/461A/861A - Summary Datasheet
PDF, 599 Кб, Файл опубликован: 1 май 2011
Купить ATtiny861A на РадиоЛоцман.Цены — от 49 до 376 ₽ 43 предложений от 26 поставщиков 8-битные микроконтроллеры 8K Flash;125B EEPROM 128B SRAM;16 IO Pins | |||
ATtiny861A-SU Atmel | 49 ₽ | ||
AttINY861A-PU Atmel | 68 ₽ | ||
ATTINY861A-MU Microchip | 218 ₽ | ||
ATTINY861A-XU Atmel | по запросу |
ATTINY861A-MU | ATTINY861A-MUR | ATTINY861A-PU | ATTINY861A-SU | ATTINY861A-SUR | ATTINY861A-XU | ATTINY861A-XUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
Корпус | VQFN | VQFN | PDIP | SOIC | SOIC | TSSOP | TSSOP |
Parameters / Models | ATTINY861A-MU | ATTINY861A-MUR | ATTINY861A-PU | ATTINY861A-SU | ATTINY861A-SUR | ATTINY861A-XU | ATTINY861A-XUR |
ADC Input | 11 | 11 | 11 | 11 | 11 | 11 | 11 |
ADC with Computation | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 512 | 512 | 512 | 512 | 512 | 512 | 512 |
High Voltage Capable | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 32 | 32 | 20 | 20 | 20 | 20 | 20 |
Math Accelerator | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max 8-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Max PWM outputs, including complementary | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 5x5x1mm | 5x5x1mm | .300in | .300in | .300in | 4.4mm | 4.4mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No |
Pin count | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Размер памяти программ, KB | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
SPI | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
SRAM, Bytes | 512 | 512 | 512 | 512 | 512 | 512 | 512 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
Zero Cross detect | No | No | No | No | No | No | No |
Серия: ATtiny861A (7)
- Microcontrollers > 8-bit Microcontrollers
