Datasheet Microchip ATTINY48-AUR — Даташит
Производитель | Microchip |
Серия | ATtiny48 |
Модель | ATTINY48-AUR |
The Microchip picoPower 8-bit AVR RISC-based microcontroller features 4KB of ISP Flash, 64-byte EEPROM, 256-byte SRAM, 8-bit timer/counter and 16-bit timer/counter with PWM, 10-bit A/D converter, SPI, and debugWIRE for on-chip-debug
Datasheet Complete ATtiny48, ATtiny88
PDF, 8.5 Мб, Файл опубликован: 1 апр 2011, Страниц: 302
Купить ATTINY48-AUR на РадиоЛоцман.Цены — от 38 до 315 ₽ 28 предложений от 16 поставщиков RISC Microcontroller, 8Bit, FLASH, AVR RISC CPU, 12MHz, CMOS, PQFP32, 7 X 7MM, 1MM HEIGHT, 0.8MM PITCH, GREEN, PLASTIC, MS-026ABA, TQFP-32... | |||
ATTINY48-AUR Microchip | 38 ₽ | ||
ATTINY48-AUR Atmel | 94 ₽ | ||
ATTINY48-AUR Microchip | от 114 ₽ | ||
ATTINY48-AUR Microchip | от 269 ₽ |
Корпус | TQFP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 64 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 32 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 12 МГц |
Max PWM outputs | 2 including complementary |
Количество компараторов | 1 |
Package Width | 7x7x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 32 |
Размер памяти программ | 4 KB |
SPI | 1 |
SRAM | 256 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: ATtiny48 (9)
- Microcontrollers > 8-bit Microcontrollers
ATTINY48AUR, ATTINY48 AUR
