Datasheet Microchip ATTINY88-MUR — Даташит
Производитель | Microchip |
Серия | ATtiny88 |
Модель | ATTINY88-MUR |
The high-performance Microchip picoPower AVR RISC-based CMOS 8-bit microcontroller combines 8KB ISP flash memory, 64B EEPROM, 512-Byte SRAM, 28 general purpose I/O lines, 32 general purpose working registers, two flexible timer/counters with compare modes, internal and external interrupts, a byte-oriented 2-wire serial interface, SPI serial port, 6-channel 10-bit A/D converter (8-channel in 32-lead TQFP and 32-pad QFN packages), programmable watchdog timer with internal oscillator, and three software selectable power saving modes
Datasheet Complete ATtiny48, ATtiny88
PDF, 8.5 Мб, Файл опубликован: 1 апр 2011, Страниц: 302
Купить ATTINY88-MUR на РадиоЛоцман.Цены — от 35 до 277 ₽ 29 предложений от 17 поставщиков IC: микроконтроллер AVR; EEPROM: 64Б; SRAM: 512Б; Flash: 8кБ; VQFN32 | |||
ATTINY88-MUR Microchip | 35 ₽ | ||
ATTINY88-MUR Microchip | 90 ₽ | ||
ATTINY88-MUR Microchip | от 116 ₽ | ||
ATTINY88-MUR | от 277 ₽ |
Корпус | VQFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 64 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 32 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 12 МГц |
Max PWM outputs | 2 including complementary |
Количество компараторов | 1 |
Package Width | 5x5x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 32 |
Размер памяти программ | 8 KB |
SPI | 1 |
SRAM | 512 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: ATtiny88 (10)
- Microcontrollers > 8-bit Microcontrollers
ATTINY88MUR, ATTINY88 MUR
