Datasheet Microchip DSPIC33EP512MU814T-E/PH — Даташит
Производитель | Microchip |
Серия | dsPIC33EP512MU814 |
Модель | DSPIC33EP512MU814T-E/PH |
MicrochipвЂs dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPICВ® DSC core with integrated DSP and enhanced on-chip peripherals
dsPIC33EPXXX(GP/MC/MU)806/810/814 and PIC24EPXXX(GP/GU)810/814 Data Sheet
PDF, 5.2 Мб, Версия: 10-17-2012
MCU 16-bit dsPIC 536KB Flash 3.3V Automotive 144-Pin TQFP T/R | |||
DSPIC33EP512MU814T-I/PH Microchip | по запросу | ||
Корпус | TQFP |
Количество выводов | 144 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 30 including complementary outputs |
Max 16 Bit Digital Timers | 9 |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 60 |
Number of USB Modules | 1 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 144 |
Размер памяти программ | 512 Kbytes |
RAM | 53248 bytes |
SPIв„ў | 4 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 32 |
UART | 4 |
Zero Cross detect | No |
dsPIC33EP256MU806 dsPIC33EP256MU810 dsPIC33EP256MU814 dsPIC33EP512GP806 dsPIC33EP512MC806 dsPIC33EP512MU810
Серия: dsPIC33EP512MU814 (8)
DSPIC33EP512MU814TE/PH, DSPIC33EP512MU814T E/PH
