Datasheet Microchip DSPIC33FJ16GS402T-I/MM — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ16GS402 |
Модель | DSPIC33FJ16GS402T-I/MM |
dsPIC33FJXXGSXXX SMPS & Digital Power Conversion 16-bit Digital Signal Controller
dsPIC33FJ06GS101/X02 and dsPIC33FJ16GSX02/X04 Data Sheet
PDF, 3.7 Мб, Версия: 05-13-2014
Купить DSPIC33FJ16GS402T-I/MM на РадиоЛоцман.Цены — от 217 до 811 ₽ 9 предложений от 9 поставщиков dsPIC dsPICTM33F Microcontroller IC 16-Bit 40 MIPs 16KB (16K x 8) FLASH 28-QFN-S (6x6) | |||
DSPIC33FJ16GS402T-I/MM Microchip | 217 ₽ | ||
DSPIC33FJ16GS402T-I/MM Microchip | 364 ₽ | ||
DSPIC33FJ16GS402T-I/MM Microchip | по запросу | ||
Корпус | QFN-S |
Количество выводов | 28 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 3 |
Max A/D Resolution | 10 bits |
Max. CPU Speed MHz | 40 |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 16 Kbytes |
RAM | 2048 bytes |
SPIв„ў | 1 |
Temp. Range Max. | 150 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
UART | 1 |
Zero Cross detect | No |
dsPIC33FJ16GS404 dsPIC33FJ16GS502 dsPIC33FJ16GS504
Серия: dsPIC33FJ16GS402 (16)
- DSPIC33FJ16GS402-50I/MM DSPIC33FJ16GS402-50I/SO DSPIC33FJ16GS402-50I/SP DSPIC33FJ16GS402-E/MM DSPIC33FJ16GS402-E/SO DSPIC33FJ16GS402-E/SP DSPIC33FJ16GS402-H/MM DSPIC33FJ16GS402-H/SP DSPIC33FJ16GS402-I/MM DSPIC33FJ16GS402-I/SO DSPIC33FJ16GS402-I/SP DSPIC33FJ16GS402T-50I/MM DSPIC33FJ16GS402T-50I/SO DSPIC33FJ16GS402T-E/MM DSPIC33FJ16GS402T-H/MM DSPIC33FJ16GS402T-I/MM
DSPIC33FJ16GS402TI/MM, DSPIC33FJ16GS402T I/MM
