Datasheet Microchip ATTINY816-MNR — Даташит
Производитель | Microchip |
Серия | ATTINY816 |
Модель | ATTINY816-MNR |
The ATtiny816 microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with 8KB Flash, 512B SRAM and 128 bytes of EEPROM in 20-pin packages
ATtiny416/816 Summary Data Sheet
PDF, 1.1 Мб, Файл опубликован: 13 июл 2017
ATtiny416/ATtiny417/ATtiny816/ATtiny817 Automotive Data Sheet
PDF, 4.8 Мб, Файл опубликован: 1 июн 2018
Купить ATTINY816-MNR на РадиоЛоцман.Цены — от 28 до 154 ₽ 24 предложений от 12 поставщиков AVR tinyAVRTM1, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 8KB (8K x 8) FLASH 20-VQFN (3x3) | |||
ATTINY816-MNR Microchip | 28 ₽ | ||
ATTINY816-MNR Microchip | 63 ₽ | ||
ATTINY816-MNR Microchip | 126 ₽ | ||
ATTINY816-MNR Microchip | по запросу |
Корпус | VQFN |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | Yes |
Class B Hardware | Yes |
Configurable Logic Cell | 1 CLC/CCL |
Emulated EEPROM in Flash | 128 / HEF |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 20 MHz, 32 kHz |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 2 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 3 |
Number of DACs | 1 |
Package Width | 3x3x0.9mm |
Pin count | 20 |
Размер памяти программ | 8 KB |
SPI | 1 |
SRAM | 512 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: ATTINY816 (6)
- ATTINY816-MF ATTINY816-MFR ATTINY816-MN ATTINY816-MNR ATTINY816-SFR ATTINY816-SNR
- Microcontrollers > 8-bit Microcontrollers
ATTINY816MNR, ATTINY816 MNR
