Datasheet Microchip ATTINY1616 — Даташит
Производитель | Microchip |
Серия | ATTINY1616 |
The ATtiny1616 is a microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with 16 KB Flash, 2 KB SRAM and 128 bytes of EEPROM in 20-pin packages
ATtiny1616/1617 Automotive Data Sheet
PDF, 4.8 Мб, Файл опубликован: 31 май 2018
ATtiny3216/ATtiny1616 Data Sheet
PDF, 4.8 Мб, Файл опубликован: 21 июн 2018
![]() 29 предложений от 14 поставщиков AVR tinyAVRTM1, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 16KB (16K x 8) FLASH 20-SOIC | |||
ATTINY1616-MFR Microchip | 45 ₽ | ||
ATTINY1616-MFR Microchip | 47 ₽ | ||
ATTINY1616-MNR Microchip | от 88 ₽ | ||
ATTINY1616-MNR Microchip | от 188 ₽ |
ATTINY1616-MFR | ATTINY1616-MNR | ATTINY1616-SFR | ATTINY1616-SNR | |
N | 1 | 2 | 3 | 4 |
Корпус | VQFN | VQFN | SOIC | SOIC |
Parameters / Models | ATTINY1616-MFR | ATTINY1616-MNR | ATTINY1616-SFR | ATTINY1616-SNR |
ADC Input | 16 | 16 | 16 | 16 |
ADC with Computation | No | No | No | No |
Angular Timer | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes | Yes | Yes |
Class B Hardware | Yes | Yes | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 | 1 | 1 |
Emulated EEPROM in Flash | 256 / HEF | 256 / HEF | 256 / HEF | 256 / HEF |
Hardware Touch Peripheral | PTC | PTC | PTC | PTC |
High Voltage Capable | No | No | No | No |
I2C | 1 | 1 | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes |
Lead Count | 20 | 20 | 20 | 20 |
Math Accelerator | No | No | No | No |
Max 16-Bit Digital Timers | 3 | 3 | 3 | 3 |
Max 8-Bit Digital Timers | 1 | 1 | 1 | 1 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 | 20 | 20 |
Max DAC Resolution, Bits | 8 | 8 | 8 | 8 |
Max PWM outputs, including complementary | 8 | 8 | 8 | 8 |
Количество компараторов | 3 | 3 | 3 | 3 |
Number of DACs | 3 | 3 | 3 | 3 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 3x3x0.9mm | 3x3x0.9mm | .300in | .300in |
Peripheral Pin Select / Pin Muxing | Yes | Yes | Yes | Yes |
Pin count | 20 | 20 | 20 | 20 |
Размер памяти программ, KB | 16 | 16 | 16 | 16 |
SPI | 1 | 1 | 1 | 1 |
SRAM, Bytes | 2048 | 2048 | 2048 | 2048 |
Temp Range Max | 125 | 125 | 125 | 125 |
Temp Range Min | -40 | -40 | -40 | -40 |
UART | 1 | 1 | 1 | 1 |
Zero Cross detect | No | No | No | No |
ATTINY1617 ATTINY3216 ATTINY3216
Серия: ATTINY1616 (4)
- Microcontrollers > 8-bit Microcontrollers
