Datasheet Microchip ATTINY214 — Даташит
Производитель | Microchip |
Серия | ATTINY214 |
The ATtiny214 is a microcontroller using the 8-bit AVR® processor with hardware multiplier, running at up to 20MHz and 2KB Flash, 128B SRAM and 64 bytes of EEPROM in a 14-pin package
Datasheet ATtiny214, ATtiny414, ATtiny814
PDF, 3.8 Мб, Файл опубликован: 13 июл 2017, Страниц: 497
AVR Microcontroller with Core Independent Peripherals and picoPower Technology
Datasheet ATtiny214, ATtiny414, ATtiny814 Summary
PDF, 491 Кб, Файл опубликован: 24 апр 2018, Страниц: 16
Купить ATTINY214 на РадиоЛоцман.Цены — от 34 до 3 968 ₽ 20 предложений от 12 поставщиков AVR tinyAVRTM1, Functional Safety (FuSa) Microcontroller IC 8-Bit 16MHz 2KB (2K x 8) FLASH 14-SOIC | |||
ATTINY214-SSF Microchip | 34 ₽ | ||
ATTINY214-SSN Microchip | 110 ₽ | ||
ATTINY20-SSUR | от 159 ₽ |
ATTINY214-SSFR | ATTINY214-SSNR | |
N | 1 | 2 |
Корпус | SOIC | SOIC |
Parameters / Models | ATTINY214-SSFR | ATTINY214-SSNR |
ADC Input | 12 | 12 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 64 / HEF | 64 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 14 | 14 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 2 | 2 |
Max 8-Bit Digital Timers | 1 | 1 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Max DAC Resolution, Bits | 8 | 8 |
Количество компараторов | 1 | 1 |
Number of DACs | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
PWM Max Resolution, Bits | 8 | 8 |
Package Width | .150In(3.90mm) | .150In(3.90mm) |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 14 | 14 |
Размер памяти программ, KB | 2 | 2 |
SPI | 1 | 1 |
SRAM, Bytes | 128 | 128 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 1 | 1 |
Zero Cross detect | No | No |
Серия: ATTINY214 (2)
- Microcontrollers > 8-bit Microcontrollers
