Datasheet Microchip PIC16LF18877T-I/ML — Даташит
Производитель | Microchip |
Серия | PIC16F18877 |
Модель | PIC16LF18877T-I/ML |
PIC16(L)F1885X/7X microcontrollers feature Analog, Core Independent Peripherals and communication peripherals, combined with eXtreme Low Power (XLP) for a wide range of general purpose and low-power applications
Купить PIC16LF18877T-I/ML на РадиоЛоцман.Цены — от 126 до 159 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 56KB (32K x 14) FLASH 44-QFN (8x8) | |||
PIC16LF18877T-I/ML Microchip | 126 ₽ | ||
PIC16LF18877T-I/ML Microchip | 128 ₽ | ||
PIC16LF18877T-I/ML Microchip | по запросу | ||
Корпус | QFN |
Количество выводов | 44 |
ADC Input | 35 |
ADC with Computation | Yes |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Hardware | Yes |
Complementary Waveform Generator / Complementary Output Generator | 3 |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 256 |
Hardware Limit Timer | 3 |
Hardware Touch Peripheral | ADC2 with HCVD |
High Voltage Capable | No |
I2C | 2 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 3 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 19 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 1 |
Pin count | 40 |
Размер памяти программ | 56 KB |
SPI | 2 |
SRAM | 4096 Bytes |
Signal Measurement Timer | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F18877 (30)
- PIC16F18877-E/ML PIC16F18877-E/MV PIC16F18877-E/MVVAO PIC16F18877-E/P PIC16F18877-E/PT PIC16F18877-I/ML PIC16F18877-I/MV PIC16F18877-I/P PIC16F18877-I/PREL PIC16F18877-I/PT PIC16F18877T-E/MV PIC16F18877T-E/MVVAO PIC16F18877T-I/ML PIC16F18877T-I/MV PIC16F18877T-I/PT PIC16LF18877-E/ML PIC16LF18877-E/MV PIC16LF18877-E/P PIC16LF18877-E/PT PIC16LF18877-I/ML PIC16LF18877-I/MV PIC16LF18877-I/MVC04 PIC16LF18877-I/P PIC16LF18877-I/PT PIC16LF18877T-I/ML PIC16LF18877T-I/MV PIC16LF18877T-I/MVC04 PIC16LF18877T-I/PT PIC16LF18877T-I/PTC01 PIC16LF18877T-I/PTRA3
- Microcontrollers > 8-bit Microcontrollers
PIC16LF18877TI/ML, PIC16LF18877T I/ML
