Datasheet Microchip PIC16F1618-E/P — Даташит
Производитель | Microchip |
Серия | PIC16F1618 |
Модель | PIC16F1618-E/P |
PIC16(L)F161X microcontrollers deliver on-chip features that are unique to the design for embedded control of small motors and general purpose applications in 8 / 14 / 20 pin count packages
PIC16(L)F1614/8 14/20-Pin, 8-Bit Flash MCU Data Sheet
PDF, 5.7 Мб, Файл опубликован: 3 ноя 2017
Купить PIC16F1618-E/P на РадиоЛоцман.Цены — от 104 до 589 ₽ 13 предложений от 10 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 7KB (4K x 14) FLASH 20-PDIP | |||
PIC16F1618-E/P Microchip | 104 ₽ | ||
PIC16F1618-E/P Microchip | 130 ₽ | ||
PIC16F1618-E/P Microchip | 162 ₽ | ||
PIC16F1618-E/P Microchip | по запросу |
Корпус | PDIP |
Количество выводов | 20 |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | Yes |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Hardware | Yes |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 2 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 3 |
High Voltage Capable | No |
I2C | 1 |
Math Accelerator | Yes |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Рабочий диапазон температур | от -40 до +125 °C |
Pin count | 20 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 512 Bytes |
Signal Measurement Timer | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1618 (28)
- PIC16F1618-E/GZ PIC16F1618-E/ML PIC16F1618-E/P PIC16F1618-E/SO PIC16F1618-E/SS PIC16F1618-I/GZ PIC16F1618-I/ML PIC16F1618-I/P PIC16F1618-I/SO PIC16F1618-I/SS PIC16F1618T-I/GZ PIC16F1618T-I/ML PIC16F1618T-I/SO PIC16F1618T-I/SS PIC16LF1614-E/P PIC16LF1614-I/P PIC16LF1618-E/ML PIC16LF1618-E/P PIC16LF1618-E/SO PIC16LF1618-E/SS PIC16LF1618-I/GZ PIC16LF1618-I/ML PIC16LF1618-I/P PIC16LF1618-I/SO PIC16LF1618-I/SS PIC16LF1618T-I/ML PIC16LF1618T-I/SO PIC16LF1618T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16F1618E/P, PIC16F1618 E/P
