Datasheet Microchip PIC16F1619T-I/SO — Даташит
Производитель | Microchip |
Серия | PIC16F1619 |
Модель | PIC16F1619T-I/SO |
PIC16(L)F161X microcontrollers deliver on-chip features that are unique to the design for embedded control of small motors and general purpose applications in 8 / 14 / 20 pin count packages
PIC16(L)F1615/9 14/20-Pin, 8-Bit Flash MCU Data Sheet
PDF, 5.8 Мб, Файл опубликован: 3 ноя 2017
Купить PIC16F1619T-I/SO на РадиоЛоцман.Цены — от 80 до 119 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F, Functional Safety (FuSa) Microcontroller IC 8-Bit 32MHz 14KB (8K x 14) FLASH 20-SOIC | |||
PIC16F1619T-I/SO Microchip | 80 ₽ | ||
PIC16F1619T-I/SO Microchip | 117 ₽ | ||
PIC16F1619T-I/SO Microchip | 119 ₽ | ||
PIC16F1619T-I/SO Microchip | по запросу |
Корпус | SOIC |
Количество выводов | 20 |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | Yes |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Hardware | Yes |
Complementary Waveform Generator / Complementary Output Generator | 1 |
Configurable Logic Cell | 4 CLC/CCL |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 3 |
High Voltage Capable | No |
I2C | 1 |
Math Accelerator | Yes |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Pin count | 20 |
Размер памяти программ | 14 KB |
SPI | 1 |
SRAM | 1024 Bytes |
Signal Measurement Timer | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1619 (25)
- PIC16F1619-E/ML PIC16F1619-E/P PIC16F1619-E/SO PIC16F1619-E/SS PIC16F1619-I/ML PIC16F1619-I/P PIC16F1619-I/SO PIC16F1619-I/SS PIC16F1619-ME2/PF PIC16F1619T-E/SS PIC16F1619T-E/SSVAO PIC16F1619T-I/ML PIC16F1619T-I/SO PIC16F1619T-I/SS PIC16LF1619-E/ML PIC16LF1619-E/P PIC16LF1619-E/SO PIC16LF1619-E/SS PIC16LF1619-I/ML PIC16LF1619-I/P PIC16LF1619-I/SO PIC16LF1619-I/SS PIC16LF1619T-I/ML PIC16LF1619T-I/SO PIC16LF1619T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16F1619TI/SO, PIC16F1619T I/SO
