Datasheet Linear Technology LTM2881IY-5 — Даташит
Серия | LTM2881-5 |
Модель | LTM2881IY-5 |
Complete Isolated RS485/RS422 µModule Transceiver + Power
Datasheet LTM2881
PDF, 594 Кб, Язык: анг., Файл закачен: 12 ноя 2017, Страниц: 24
Complete Isolated RS485/RS422 μModule Transceiver + Power
Купить LTM2881IY-5 на РадиоЛоцман.Цены — от 787 до 7 278 ₽ 20 предложений от 16 поставщиков IC: интерфейс; цифровой изолятор,трансивер; RS422 / RS485; BGA32 | |||
LTM2881IY-5#PBF Linear Technology | 787 ₽ | ||
LTM2881IY-5#PBF Analog Devices | 1 049 ₽ | ||
LTM2881IY-5#PBF Analog Devices | 2 144 ₽ | ||
LTM2881IY-5 Analog Devices | 3 370 ₽ |
Корпус | 15mm x 11.25mm x 3.42mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1851 |
Demo Boards | DC1503A-A,DC1503A-B,DC1746A-A,DC1746A-B |
Drivers | 1 |
Экспортный контроль | нет |
Основные особенности | Adjustable Slew Rate, Isolated |
Isolation Rating | 2500 Vrms |
Max Data Rate | 20 Mbps |
Protocols Supported | RS485, RS422, PROFIBUS |
Receivers | 1 |
Диапазон напряжения питания | 4.5V to 5.5V |
Termination | Included |
RoHS | Не совместим |
- Using the LTM2881 as an Isolated 5V Power Supply &mdash AN125PDF, 95 Кб, Файл опубликован: 5 фев 2010
The LTM2881 is an isolated RS485 transceiver that guards against large ground-to-ground differentials. An onboard DC/DC converter provides isolated 5V power to the output. This application note shows the LTM2881 configured as a dedicated isolated power supply with the RS485 transceiver disabled, providing a simple powerful general purpose isolated power supply capable of delivering 1W at 5V.Выписка из документа
Статьи
- Isolated Data Transmission and Power Conversion Integrated Into a Surface Mount Package &mdash LT JournalPDF, 1.4 Мб, Файл опубликован: 18 янв 2011Выписка из документа
Серия: LTM2881-5 (10)
- Interface > Isolated Transceivers > µModule Isolated Transceivers
- Interface > RS485/RS422 Transceivers | Extended Temperature (H & MP) Interface
LTM2881IY5, LTM2881IY 5
