Datasheet Intersil ISL88739 — Даташит
Производитель | Intersil |
Серия | ISL88739 |
Hybrid Power Boost (HPB) and Narrow VDC (NVDC) Combo Battery Charger With SMBus Interface
Data Short ISL88739
PDF, 193 Кб, Версия: 24-10-2017, Файл закачен: 19 ноя 2017, Страниц: 2
Купить ISL88739 на РадиоЛоцман.Цены — от 112 до 954 ₽ 30 предложений от 14 поставщиков Зарядное устройство, 4-элементная Li-Ion, Li-Pol батарея, гибридное повышение питания/узкое VDC, 22В | |||
ISL88739AHRZ Intersil | от 112 ₽ | ||
ISL88739AHRZ Intersil | от 114 ₽ | ||
ISL88739HRZ Renesas | от 708 ₽ | ||
ISL88739BHRZ-T Renesas | по запросу |
ISL88739HRZ | ISL88739HRZ-T | |
N | 1 | 2 |
Корпус | 32 Ld QFN | 32 Ld QFN T+R |
Parameters / Models | ISL88739HRZ | ISL88739HRZ-T |
Audible Noise | No | No |
Automatic Power Source Selection | No (Set by Host) | No (Set by Host) |
Automatic Trickle Charge Typ (V) | 2.7 | 2.7 |
Battery Charge Voltage (V) | 1.024 to 19.2 in 16mV Steps | 1.024 to 19.2 in 16mV Steps |
Battery Charge Voltage Adjust (%) | 16mV steps | 16mV steps |
Battery Chemistry | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer |
Battery Leakage Current Max (μA) | 2 (DCIN=0V, No System Load) | 2 (DCIN=0V, No System Load) |
Battery Leakage Current Max (ОјA) | 2 (DCIN=0V, No System Load) | 2 (DCIN=0V, No System Load) |
Charge Current Limit Accuracy (%) | В±3 | В±3 |
Charging Voltage Accuracy Max (%) | В±0.5 | В±0.5 |
DC Adapter Detection | No (Set by Host) | No (Set by Host) |
Description | Hybrid Power Boost (HPB) and Narrow VDC (NVDC) Combo Battery Charger With SMBus Interface | Hybrid Power Boost (HPB) and Narrow VDC (NVDC) Combo Battery Charger With SMBus Interface |
Input Current Limit Accuracy (%) | В±3 | В±3 |
Max Duty Cycle (%) | 99.6 | 99.6 |
Рабочий диапазон температур | от 0 до 70 | от 0 до 70 |
Peak Temp | 260°C | 260°C |
Qualification Level | Standard | Standard |
Switching Frequency (typ) (kHz) | 400 | 400 |
Thermal Shutdown (В°C) | 150 °C | 150 °C |
Topology | Fixed Frequency Synchronous Buck | Fixed Frequency Synchronous Buck |
Trickle Charge Current Limit Accuracy (%) | 64mA to 220mA | 64mA to 220mA |
VIN (max) (V) | 22 | 22 |
VIN (min) (V) | 8 | 8 |
Серия: ISL88739 (2)
- Power Management > Battery Management Systems > Multiple Cell Battery Chargers
