Datasheet Intersil ISL6298 — Даташит
Производитель | Intersil |
Серия | ISL6298 |
Li-ion/Li-Polymer Battery Charger
Купить ISL6298 на РадиоЛоцман.Цены — от 23 до 356 ₽ 27 предложений от 21 поставщиков Battery Charger Li-Ion/Li-Pol 75mA to 450mA 4.2V 16Pin QFN EP T/R | |||
ISL6298-2CR4Z | от 23 ₽ | ||
ISL6298-2CR4Z | от 24 ₽ | ||
ISL6298-2CR3Z Renesas | 315 ₽ | ||
ISL6298-1CR4Z-T Intersil | по запросу |
ISL6298-1CR4Z | ISL6298-1CR4Z-T | ISL6298-2CR3Z | ISL6298-2CR3Z-T | ISL6298-2CR4Z | ISL6298-2CR4Z-T | ISL6298CR4Z | ISL6298CR4Z-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 16 Ld QFN | 16 Ld QFN T+R | 10 Ld DFN | 10 Ld DFN T+R | 16 Ld QFN | 16 Ld QFN T+R | 16 Ld QFN | 16 Ld QFN T+R |
Parameters / Models | ISL6298-1CR4Z | ISL6298-1CR4Z-T | ISL6298-2CR3Z | ISL6298-2CR3Z-T | ISL6298-2CR4Z | ISL6298-2CR4Z-T | ISL6298CR4Z | ISL6298CR4Z-T |
Accepts CC Adapter | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Battery Chemistry | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer | Single Cell Li+/Polymer |
Description | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger | Li-ion/Li-Polymer Battery Charger |
Function(s) | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage | Enable,Charge Status,Fault Indiction,NTC Input,Timeout Disable,Programmable IMIN,Reference Voltage |
IOUT1 (max) (A) | 0.45 | 0.45 | 0.45 | 0.45 | 0.45 | 0.45 | 0.45 | 0.45 |
IOUT2 (max) (A) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
Рабочий диапазон температур | от See Datasheet | от See Datasheet | от See Datasheet | от See Datasheet | от See Datasheet | от See Datasheet | от See Datasheet | от See Datasheet |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Safety Timer | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Self Termination | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Thermal Regulation | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
VIN1 (max) | 7 V | 7 V | 7 V | 7 V | 7 V | 7 V | 7 V | 7 V |
VIN1 Trickle Charge (min) (% CC) | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
VIN2 (max) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
VIN2 Trickle Charge (min) (% CC) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
VOUT (typ) (V) | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 | 4.1, 4.2 |
Voltage Accuracy (%) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL6298 (8)
- Power Management > Battery Management Systems > Single Cell Battery Chargers
