Datasheet Intersil ISL28291 — Даташит
Производитель | Intersil |
Серия | ISL28291 |
Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp
Купить ISL28291 на РадиоЛоцман.Цены — от 65 до 270 ₽ 31 предложений от 21 поставщиков IC, OP-AMP, 61 MHz, 17 V/µs, MSOP-10 - More Details | |||
ISL28230FBZ ISL78307FBEBZ ISL80136IBEAJZ ISL28230CBZ ISL28207FBZ ISL6140IBZ ISL12058IBZ ISL28291FBZ ISL83085EIBZ ISL83088, | 65 ₽ | ||
ISL28291FRUZ-T7 Intersil | 81 ₽ | ||
ISL28291FUZ-T7 | от 124 ₽ | ||
ISL28291FUZ Renesas | 140 ₽ |
ISL28291FBZ | ISL28291FBZ-T7 | ISL28291FRUZ-T7 | ISL28291FUZ | ISL28291FUZ-T7 | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 10 Ld uTQFN T+R | 10 Ld MSOP | 10 Ld MSOP T+R |
Parameters / Models | ISL28291FBZ | ISL28291FBZ-T7 | ISL28291FRUZ-T7 | ISL28291FUZ | ISL28291FUZ-T7 |
2nd Harmonic | -76 dB | -76 dB | -76 dB | -76 dB | -76 dB |
3rd Harmonic | -70 dB | -70 dB | -70 dB | -70 dB | -70 dB |
AVOL | 98 dB | 98 dB | 98 dB | 98 dB | 98 dB |
Полоса частот | 61 MHz | 61 MHz | 61 MHz | 61 MHz | 61 MHz |
Количество каналов | 2 | 2 | 2 | 2 | 2 |
Коэффициент подавления синфазного сигнала | 100 dB | 100 dB | 100 dB | 100 dB | 100 dB |
Description | Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp | Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp | Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp | Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp | Dual Supply Ultra-Low Noise, Low Distortion Rail-to-Rail Output, Op Amp |
Distortion Conditions | 2Vpp, 1MHz | 2Vpp, 1MHz | 2Vpp, 1MHz | 2Vpp, 1MHz | 2Vpp, 1MHz |
Enable | Yes | Yes | Yes | Yes | Yes |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 |
IBIAS | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA |
IBIAS (max) | 6 μA | 6 μA | 6 μA | 6 μA | 6 μA |
IOUT | 130 mA | 130 mA | 130 mA | 130 mA | 130 mA |
IS (per amp) | 2.6 mA | 2.6 mA | 2.6 mA | 2.6 mA | 2.6 mA |
Noise VN | 1.7 nV/√Hz | 1.7 nV/√Hz | 1.7 nV/√Hz | 1.7 nV/√Hz | 1.7 nV/√Hz |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Output Headroom | 5 V | 5 V | 5 V | 5 V | 5 V |
PSRR | 80 dB | 80 dB | 80 dB | 80 dB | 80 dB |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | -Vs | -Vs | -Vs | -Vs | -Vs |
Rail-to-Rail Output | Yes | Yes | Yes | Yes | Yes |
Скорость нарастания | 17 V/μs | 17 V/μs | 17 V/μs | 17 V/μs | 17 V/μs |
Thermal Shutdown | No | No | No | No | No |
Topology | VFA | VFA | VFA | VFA | VFA |
VOS (max) | 0.63 mV | 0.63 mV | 0.63 mV | 0.63 mV | 0.63 mV |
VOUT | 4.97 V | 4.97 V | 4.97 V | 4.97 V | 4.97 V |
VS (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VS (min) | 3 V | 3 V | 3 V | 3 V | 3 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL28291 (5)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
