Datasheet Intersil HFA1100 — Даташит
Производитель | Intersil |
Серия | HFA1100 |
850MHz, Low Distortion Current Feedback Operational Amplifiers
![]() 23 предложений от 20 поставщиков Radiation Hardened, Ultra High Speed Current Feedback Amplifier | |||
HFA1100IB Intersil | 71 ₽ | ||
HFA1100IB | от 171 ₽ | ||
HFA1100IP Intersil | 393 ₽ | ||
HFA1100IBZ Intersil | по запросу |
HFA1100IB | HFA1100IB96 | HFA1100IBZ | HFA1100IBZ96 | HFA1100IP | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld PDIP |
Parameters / Models | HFA1100IB | HFA1100IB96 | HFA1100IBZ | HFA1100IBZ96 | HFA1100IP |
2nd Harmonic | -56 dB | -56 dB | -56 dB | -56 dB | -56 dB |
3rd Harmonic | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB |
AVOL | 110 dB | 110 dB | 110 dB | 110 dB | 110 dB |
Полоса частот | 850 MHz | 850 MHz | 850 MHz | 850 MHz | 850 MHz |
Количество каналов | 1 | 1 | 1 | 1 | 1 |
Коэффициент подавления синфазного сигнала | 46 dB | 46 dB | 46 dB | 46 dB | 46 dB |
Description | 850MHz, Low Distortion Current Feedback Operational Amplifiers | 850MHz, Low Distortion Current Feedback Operational Amplifiers | 850MHz, Low Distortion Current Feedback Operational Amplifiers | 850MHz, Low Distortion Current Feedback Operational Amplifiers | 850MHz, Low Distortion Current Feedback Operational Amplifiers |
Diff Gain (%) | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 |
Diff Phase (В°) | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Distortion Conditions | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz |
Enable | No | No | No | No | No |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 |
IBIAS | 2.5 μA | 2.5 μA | 2.5 μA | 2.5 μA | 2.5 μA |
IBIAS (max) | 40 μA | 40 μA | 40 μA | 40 μA | 40 μA |
IOUT | 60 mA | 60 mA | 60 mA | 60 mA | 60 mA |
IS (per amp) | 21 mA | 21 mA | 21 mA | 21 mA | 21 mA |
Noise VN | 4 nV/√Hz | 4 nV/√Hz | 4 nV/√Hz | 4 nV/√Hz | 4 nV/√Hz |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Headroom | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V |
PSRR | 50 dB | 50 dB | 50 dB | 50 dB | 50 dB |
Peak Temp | 240°C | 240°C | 260°C | 260°C | |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | No | No | No | No | No |
Rail-to-Rail Output | No | No | No | No | No |
Скорость нарастания | 2300 V/μs | 2300 V/μs | 2300 V/μs | 2300 V/μs | 2300 V/μs |
Thermal Shutdown | No | No | No | No | No |
Topology | CFA | CFA | CFA | CFA | CFA |
VOS (max) | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV |
VOUT | 6.6 V | 6.6 V | 6.6 V | 6.6 V | 6.6 V |
VS (max) | 11 V | 11 V | 11 V | 11 V | 11 V |
VS (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
Серия: HFA1100 (5)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
