Datasheet Intersil HI5960 — Даташит
Производитель | Intersil |
Серия | HI5960 |
14-Bit, 130MSPS, CommLink High Speed D/A Converter
![]() 17 предложений от 17 поставщиков Цифро-аналоговые преобразователи (ЦАП) 28 -40 85C 14 BIT 125MSPS CMOS DACPE | |||
HI5960IA-T Intersil | 71 ₽ | ||
HI5960IAZ-T Intersil | 734 ₽ | ||
HI5960SOICEVAL1 Intersil | по запросу | ||
HI5960IB Renesas | по запросу |
HI5960IA | HI5960IA-T | HI5960IAZ | HI5960IAZ-T | HI5960IB | HI5960IBZ | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld SOIC | 28 Ld SOIC |
Parameters / Models | HI5960IA | HI5960IA-T | HI5960IAZ | HI5960IAZ-T | HI5960IB | HI5960IBZ |
± DNL (Diff. Non-Linearity) (LSB) | 3 | 3 | 3 | 3 | 3 | 3 |
± INL (Integral Non-Linearity) (LSB) | 5 | 5 | 5 | 5 | 5 | 5 |
Description | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter | 14-Bit, 130MSPS, CommLink? High Speed D/A Converter |
Max Conv Rate (MSPS) | 130 | 130 | 130 | 130 | 130 | 130 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output I/V | I | I | I | I | I | I |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 260°C |
Power (mW) | 84mW at 130Msps (3V) | 84mW at 130Msps (3V) | 84mW at 130Msps (3V) | 84mW at 130Msps (3V) | 84mW at 130Msps (3V) | 84mW at 130Msps (3V) |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
Разрешение | 14 | 14 | 14 | 14 | 14 | 14 |
SFDR (typ) to Nyquist (dBc) | 77dBc 2.5MHz@50Msps | 77dBc 2.5MHz@50Msps | 77dBc 2.5MHz@50Msps | 77dBc 2.5MHz@50Msps | 77dBc 2.5MHz@50Msps | 77dBc 2.5MHz@50Msps |
VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
VS (max) | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V |
VS (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
В± DNL (Diff. Non-Linearity) (LSB) | 3 | 3 | 3 | 3 | 3 | 3 |
В± INL (Integral Non-Linearity) (LSB) | 5 | 5 | 5 | 5 | 5 | 5 |
Серия: HI5960 (6)
- Data Converters > D/A Converters > D/A Converters
